Author Topic: Dux 2 chip will not boot with eject button  (Read 4427 times)
fairway2000
  • Last login:April 21, 2012, 06:53:54 pm
  • Loooking for games in Detroit
« on: December 21, 2005, 09:11:17 am »
I have this Dux 2 chip http://www.duomodchip.com/english/install/duox2_white/duox2_white_v1.0.jpg
It will boot to Mod chip but when I use eject button it goes red and the screen
said "Your Xbox needs service" What could this be? I have M8_16.bin bios.
I did chose a option and one time to unlock hard drive.Could that do it?
Isn't this fun
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
Re: Dux 2 chip will not boot with eject button
« Reply #1 on: December 21, 2005, 09:30:23 am »
what error code are you getting?  When it says "your xbox needs service" thee will be a number in the corner.  See what it is and look up the code.
If you're trying to boot with the modchip off and you unlocked your hard drive, you're probably getting an error 5.. and yes, that's because you unlocked your hard drive.
first off your and idiot
fairway2000
« Reply #2 on: December 21, 2005, 10:53:51 am »
There is no code that I can see.Do you know how to lock it again.I don't have the same bios as I did when I locked it.
fairway2000
« Reply #3 on: December 21, 2005, 12:54:34 pm »
HELP all I get now is a Green then red light on the on/off switch.
pointdablame
« Reply #4 on: December 21, 2005, 01:56:28 pm »
That's known as a FRAG... Flashing Red And Green.  Don't go crazy.
Will your Xbox boot up with the chip?  Do you get an error message still?  If you do, there WILL be a number in the corner of the screen.  If not, something is really screwy.
fairway2000
« Reply #5 on: December 21, 2005, 02:04:25 pm »
Ok I changed my switch to Mode 1 now it works.I'm running m8plus bios.
Now how do you get the dash board to run?Is that my next step?
pointdablame
« Reply #6 on: December 21, 2005, 05:41:20 pm »
I assume you mean you want the original microsoft dash to run.  To do that you need to lock that hard drive again and change your file structure in your hard drive so tha tthe original MS dash files are still there.
I don't have the exact work through for it since I don't bother running the MS dash on my modded xbox, but go to xbox-scene.com and look at the tutorials.  It's in there.
fairway2000
« Reply #7 on: December 21, 2005, 09:23:14 pm »
I would like the new dashboard old one is running ok.What can be done?
Copy games?Put games on hard drive?
fairway2000
« Reply #8 on: December 21, 2005, 11:11:10 pm »
Ok. I am dieing here.Please help.What can I do with this chip?
I have been looking at putting a Newdashboard on it.I can't get this xbox
to see my boot disk.HEEELLLPPPP
pointdablame
« Reply #9 on: December 22, 2005, 01:09:29 am »
ok you don't seem very farmiliar with this, and you also don't seem like you want to read anything on xbox-scene, so just go find yourself an iso of Slayer's EvoX installer v2.6
Burn that.
Put in Xbox.
Turn Xbox on.
Press buttona few times, and all the goodies you need will be put on your hard drive.
Enjoy your xbox.
You can find the iso in the "regular places" online, or on the xbins IRC chat/FTP site.
fairway2000
« Reply #10 on: December 22, 2005, 09:20:46 am »
I have tried that.It will not see the disk I made.I made a image disk,burned it
and it will not see the disk.Should the image disk be a boot disk?The program I used it is not.
« Last Edit: December 22, 2005, 11:13:08 am by fairway2000 »
pointdablame
« Reply #11 on: December 22, 2005, 02:35:28 pm »
what media are you using, and what dvd drive is in your xbox?
In general, you'll have the most luck using DVD-R discs (at least in my experience).  Also, depending on what drive you have (Thompson, Samsung, or Philips) you may not be able to read certain types of media at all.
fairway2000
« Reply #12 on: December 22, 2005, 03:26:15 pm »
Thompson and nero.I'm using a cd-rw.I'm about to load up the shot gun.LOL
I will try a DVD-r next.
Thanks again
fairway2000
« Reply #13 on: December 22, 2005, 04:27:50 pm »
Do I have to make the ISO file from the EvoX2.6 a image file before burning?
fairway2000
« Reply #14 on: December 22, 2005, 04:38:13 pm »
Got it.Had to use Clone DVD and a DRD-R.
pointdablame
« Reply #15 on: December 23, 2005, 12:37:47 am »
Thompsons don't like CDRW's in my experience.  I know there are some people that say their tommys can read everything... but I haven't seen it.  Stick with DVD-Rs from now on and you should be ok.
fairway2000
« Reply #16 on: December 25, 2005, 12:34:09 am »
I installed a 160gb hard drive and now it will not boot with eject.I do have a back up of the stock drive. Am I missing something?
pointdablame
« Reply #17 on: December 25, 2005, 12:53:27 am »
Is the eject button trying to boot to the stock dashboard?  If so... is your hard drive unlocked.... again  :P  Unless you locked it with the Slayer's disc or similar, you won't boot to the stock dash.
fairway2000
« Reply #18 on: December 25, 2005, 10:55:06 pm »
That was it.
