Author Topic: USB PC game Pad Hack  (Read 2317 times)
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« on: December 12, 2005, 06:33:20 pm »
I tried to Hack a USB game pad to use under Arcade controllers (joystick panal).It was a 6 button and 2 axis simple game pad.
I just hold two seperate "grounds" wire ,each one going towards AXIS and BUTTONS respectively.
I arrange them all and assembled in my controller box.
Now I have a problem when playing Fighting games like KOF98.
When i quickly move the joystick Right Right,fwd fwd or reverse the character playing in the game is not running every time.There must be a delay sometimes which always irritate me.
can you help me...
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
Re: USB PC game Pad Hack
« Reply #1 on: December 12, 2005, 09:22:08 pm »
I've never come across a simple digital USB pad with a delay, and all the ones I've hacked have worked just fine.  Even the cheap $10 discount-bin pads.
Check all your wiring and solder points for loose contacts (use a multi-meter, not just your eyes).  99.99% of the time it's a bad soldering job that causes issues.  Failing that, check all of your microswitches on your sticks (again, with a multi-meter).
ahmer
  • Do as you like.
« Reply #2 on: December 13, 2005, 05:36:31 pm »
I will check again check the wiring.
just tell me how many ground do you use ?
I did with 2 ground [1 for x-y AXIS and 1 for Buttons] from thier nearest Point going towards them.
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
« Reply #3 on: December 14, 2005, 01:57:28 am »
I'd imagine the d-pad and the buttons shared a ground. But it doesnt really matter if they have "seperate" grounds since it's all coming from the same source.
ahmer
  • Do as you like.
« Reply #4 on: December 15, 2005, 07:06:29 pm »
Yeah that was also my thought.
But with gamepad hack we use wires (6 to 10 inces) long.Is
that make a differnce to increase impedence.
elvis
  • penguin poker
    • StickFreaks
« Reply #5 on: December 15, 2005, 11:29:33 pm »
I use "Quantum Fighter Pro" gamepads for hacking, because they're cheap and readily available.  These have a common ground for all components, so I have 1 ground wire.
Grab a multimeter and test your gamepad to see if it shares ground wires for different parts.  If it's a common ground, then no problems.  If there are different grounds, it could be there for a reason.  I'd go with whatever the pad manufacturer used.  No point risking your Dreamcast for a tiny piece of wire! :)
