Author Topic: Double problem in Mamewah and Daphne.. Please help  (Read 3092 times)
fabri_deasonora
  • Last login:February 14, 2010, 02:02:43 pm
« on: December 12, 2005, 06:28:13 am »
 ;) Hello everybody! nice to meet you.. it's a few I read the forum. The best.
I'm Fabri from north italy, 30 yrs male. I've just finished my mamecab in a sinistar cab (found in a dump empty).
It runs with mame 32 0.61 complete, with pinball and daphne. Riva tnt2 sending signal to a tv thru scart pins. Two joystick controllers in usb.
Now, I had finished my layout on mamewah 1.61 and mame runs perfectly. Pinball too... but I would like to solve two problems that I don't know how to do.
1st - mamewah screensaver doesn't work! I dont know why.. I need the run_random_game type but never happens! everything seems to be setted ok.
2nd I did my daphne.bat but. In the mamewah list I have different laser games but it launches always the first of my daphne.bat. Please let me know the command to insert in order to let me choose wich game to play.
And for last... just a curiosity.. it's possible in mamewah 1.61 have 3 different type of layout switching between the emulator lists. One for mame, one for pinball and the other for daphne?
I enclosed my .ini and my daphne.bat.
Sorry for my english and thanks to ev'ryone wanna help me! Tons of problems was solved reading this forum.. thanks
 ### mamewah.ini (mamewah v1.61) ###
### (Global) Screen-Saver Options ###
delay                       60
slide_duration              60
### mame.ini (mamewah v1.61) ###
emulator_title                            M.A.M.E
### List Generation Settings ###
rom_path                                  D:\mame32-061\roms
rom_extension                             zip
dat_file                                  D:\mame32-061
nms_file
catver_ini_file
list_generation_method                    rom_folder_vs_listinfo
### Execution Settings ###
emulator_executable                       D:\mame32-061\mame32.exe
commandline_format                        [name] -joy{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]-ctrlr mycab{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      D:\mame32-061\snap
artwork_2_image_path                      D:\mame32-061\marquees
artwork_3_image_path                      D:\mame32-061\cabinets
artwork_4_image_path                      D:\mame32-061\flyers
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               1
saver_type                                run_random_game
movie_path                                D:\mame32-061\snap
movie_fullscreen                          1
quit_delay                                100
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable                          C:\Programmi\CPViewer\cpviewer.exe
app_1_commandline_format                  [name] -clone [cloneof]
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
start/wait D:\daphne\daphne.exe cliff vldp -framefile D:\daphne\framefiles\cliff.txt -fullscreen
Exit
start/wait D:\daphne\daphne.exe galaxy vldp -framefile D:\daphne\framefiles\galaxy.txt -fullscreen
Exit
start/wait D:\daphne\daphne.exe ace vldp -framefile D:\daphne\framefiles\ace_framefile.txt -fullscreen
Exit
fabri_deasonora
Re: Double problem in Mamewah and Daphne.. Please help
« Reply #1 on: December 13, 2005, 03:09:02 am »
I made a mistake asking something? nobody could please help me..?
buks
  • Last login:January 28, 2011, 06:43:25 pm
  • Squash the Sno-Bees !
    • Arcade Machine Construction
« Reply #2 on: December 13, 2005, 06:41:28 am »
fabri,
I may be wrong here but you appear to have a delay of 60 MINUTES before the screensaver kicks in. And then each slide would stay on for 60 minutes.
**** EDIT - nope, I'm wrong. It is indeed 60 seconds.
I can't double check this as I'm at work and don't have mamewah installed (shame !)
As far as your daphne problems go - I'm pretty sure thats not how to do it (pause while buks searches the internet .....)
Right, I followed these instructions (it took me ages to get it to work but it did work in the end !)
see here - http://www.mamewah-setup.co.uk/html/info_settings.html#Daphne
One thing worth checking first though - make sure you can run all your daphne games through daphne loader FIRST before trying via mamewah.
good luck !
Buks
« Last Edit: December 13, 2005, 07:40:27 am by buks »
brophog
  • Last login:January 20, 2019, 03:49:41 am
« Reply #3 on: December 13, 2005, 07:14:12 am »
3 layouts is fine. Just name the -main portion of your layout the same as you did for the corresponding ini file.
If your daphne emulator has daphne.ini then the layout main file would be daphne-main.jpg
fabri_deasonora
« Reply #4 on: December 13, 2005, 08:56:41 am »
Hi.. thanks all..  Ok Brophog! it's good. I will try the procedure you said!
Bucks! thanks you very much. The link you post is the same I followed to create my .bat. The games load perfectly from daphneloader and in mamewah the same but only one game, the one at the top of my .bat, the others no.. if I choose to launch another game from the mamewah list, it launches always the same even if I start another name. I think the .bat is wrong.
buks
« Reply #5 on: December 13, 2005, 09:12:32 am »
Fabri,
Your bat file should look EXACTLY like this :
start/wait D:\daphne\Daphne.exe %1 vldp -framefile D:\daphne\framefiles\%1.txt -fullscreen
Exit
You don't need to specify every daphne game !
The "%1" bits in the batch file are translated to the actual Daphne names when they are passed from mamewah.
So if you had cliffhanger, you need to have a framefile called cliff.txt. Mamewah uses the daphne.nms file to work out what the "%1" value will be (in this example - cliff).
It took me a while to work this out at the time !
Good luck.
buks
fabri_deasonora
« Reply #6 on: December 13, 2005, 09:22:58 am »
 :D  Ohhhh god!!!
Maybe you save me!!! this night I will try your suggestion. I really hope you're right. Thanks man!!!!!!
... for the mamewah screensaver.. Do you know if I need something else? for example, mamewah screensaver works with windows screensaver settings? or is standalone?
buks
« Reply #7 on: December 13, 2005, 09:35:41 am »
totally standalone but turn off your windows screensaver just in case.
Your ini looks okay, do you see the snapshots of weach game in your mamewah skin ?
fabri_deasonora
« Reply #8 on: December 13, 2005, 11:52:20 am »
Yeah. sure. I see all the snaps, cabinets and flyer in my mamewah lyaout.. Neither of all mamewah screensavers type works.. I don't know why..
fabri_deasonora
« Reply #9 on: December 13, 2005, 11:54:24 am »
I also tried to use emusaver and other mamescreensaver that launches random games.. but no ones works..
do you think that happens 'cause I've mame32 and not the commadline version? does anybody that use mame32 have encountered this problem?
fabri_deasonora
« Reply #10 on: December 14, 2005, 05:08:24 am »
Hey Bucks! great! thanks! with your .bat daphne is good and every game is launchable.. only one problem... astron belt give me a bad command error.. in daphneloader is perfect..
for the screensaver.. nothing to do.. I can't make work it
brophog
« Reply #11 on: December 14, 2005, 05:20:24 am »
It's certainly worth a try to use Mame commandline.
fabri_deasonora
« Reply #12 on: December 14, 2005, 06:16:51 am »
yeah sure but I dont know where find a command line version 0.61
brophog
« Reply #13 on: December 14, 2005, 06:23:13 am »
Mame.net  keeps archives of official mame releases.
http://www.mame.net/oldmame.html
