Author Topic: what's the current "BEST" lightgun to use with PC monitors  (Read 3145 times)
fjser
  • Last login:March 07, 2024, 01:42:51 pm
« on: November 22, 2005, 05:00:19 pm »
Subject line says it all. My new cab is going to use a PC monitor (21 inch).  Whats the recommended light gun that is most compatible with mame?
jopenner
Re: what's the current "BEST" lightgun to use with PC monitors
« Reply #1 on: November 24, 2005, 07:45:49 am »
Someone here must have an answer for this guy.  I am looking for an answer too.
John
unclet
« Reply #2 on: November 24, 2005, 11:44:55 am »
I thought the only lightgun which works with Mame is the ActLabs PC  light gun (or Actlabs TV lightgun).  Other than that I never heard of another which works with Mame.
http://www.act-labs.com/products/gun1.htm
Cananas
  • Last login:August 27, 2017, 07:39:03 am
  • and the seventh day... PacMan was created
« Reply #3 on: November 24, 2005, 12:22:14 pm »
Yeah, actually the Act-labs gun is the best option for a PC monitor. For a TV, you can choose between this and a guncon2.
tivogre
  • Last login:July 18, 2013, 09:13:34 pm
    • ogredog.com
« Reply #4 on: November 24, 2005, 01:41:40 pm »
I have a pair of GunCons (Scorpion 3) working perfectly at 640x480 resolution on a Wells Gardner D9200.
There are working as well or better than the Actlabs (which I also own), AND I can use two of them.
I'm using Smog's driver, and a home built circuit that provides +5 and +9 power to the guns and uses Andy Warne's jpac small chip to get the composite sync from the VGA signal.
If you can build a simple circuit on breadboard, this is a GREAT option.
There are several threads about getting the GunCons working on a PC and a PC monitor in these forums.
IG-88
« Reply #5 on: November 24, 2005, 02:03:22 pm »
Do you think perhaps you could write up a little tutorial for us non-techies on how you did that? I think it be greatly appreciated!
-HarumaN
jopenner
« Reply #6 on: November 24, 2005, 07:56:11 pm »
Here here.
tivogre
    • ogredog.com
« Reply #7 on: November 25, 2005, 12:47:46 am »
I'm working on a write up for my web page.
Admittedly, it will just be my experience / summary of information available at other places on this forum / SMOG's forum.
Hope to have it done in the next couple of weeks.
