Author Topic: Trident card doesn't output a picture unless hooked to a pc monitor?  (Read 1664 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
I am having a little trouble with my trident card.  If it is hooked to a pc monitor when booted up it will output a picture.  If it is not hooked to the monitor at boot up and the monitor is plugged in later it will not output a picture.   Also when I hook it to my jpac it will not output a picture.  I have to first hook it to my pc monitor and then after it boots up I can hook it to the jpac and it then outputs a picture.
I am assuming that it waits to initialize until it gets feedback from the monitor and in the case of an arcade monitor there is no feedback.
Is there a way to fool the card.  I know that 4 of the wires on a vga connection are for monitor ID.  Can anything be done with these to cause the card to initialize and output a picture without hooking it to a pc monitor?
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
Re: Trident card doesn't output a picture unless hooked to a pc monitor?
« Reply #1 on: November 18, 2005, 10:33:36 am »
from memory one of those leads needs to go to ground to tell the card there is a monitor attached, used to get the same thing on cheapo servers I ran using S3 video cards, they used to refuse to boot with no monitor attached, I wound up linking the pin to ground on the card itself.
Popcorrin
« Reply #2 on: November 18, 2005, 04:56:27 pm »
I was hoping it would be something that simple.  Now all I have to do is find the right lead.
Do I have to worry about grounding the wrong monitor ID wire?
Jess--
    • My Botched Cab
« Reply #3 on: November 18, 2005, 05:00:19 pm »
I will have a look over my notes from the time and let you know what I found? can probably tell you which pin to gnd
Popcorrin
« Reply #4 on: November 18, 2005, 11:33:52 pm »
I would extremely appreciate it.   Thanks!
Jess--
    • My Botched Cab
« Reply #5 on: November 19, 2005, 07:04:46 am »
Hope this helps.
Pins / ID
4
« Last Edit: November 19, 2005, 07:07:20 am by Jess-- »
Popcorrin
« Reply #6 on: November 19, 2005, 11:21:27 am »
Awesome,  thanks! ;)
This could also come in handy to prevent certain resolutions being displayed on monitors that can not handle it.  I have an NEC monitor that certain pc games will try to send 1024x768 to, thus overdriving it.
Jess--
    • My Botched Cab
« Reply #7 on: November 20, 2005, 06:22:54 am »
should say that these are old (seriously old) standards, but modern video cards should still look for it because of backwards compatibility
Popcorrin
« Reply #8 on: November 21, 2005, 12:25:36 am »
I tried grounding the wires and for whatever reason it didn't work.  Looks like I will have to find another video card.  Thanks for the info.
