Author Topic: Outrun  (Read 7880 times)
coachcarstens
  • Last login:November 19, 2007, 10:42:59 pm
Outrun
« on: November 16, 2005, 07:48:52 pm »
I rencently won an Outrun (upright) at an auction.  Everything seems to be in great working order, I just have a few questions.
I think I rember that when you crashed, the wheel gave you some feedback, am I correct in this thinking?
Second, is there a power switch somewhere on the game , or you just have to pull the plug?  Also, once unplugged, does the game save the high scores, or do they reset each time?
Thanks for any help you can give, this is my first dedicated cab.  I just need to get some sideart, and ti will be perfect.
Chris
lustreking
  • Last login:October 11, 2021, 08:43:06 am
  • One Louder
Re: Outrun
« Reply #1 on: November 16, 2005, 10:11:21 pm »
The power switch on mine is at the very bottom of the cab on the right side.
coachcarstens
Re: Outrun
« Reply #2 on: November 16, 2005, 10:29:55 pm »
There appears to be stuff connected behind the CP.  I'm not sure how how many wires should be going up there, but I think there are only two wires going up to that stuff.
For some reason, there appears to be no switch anywhere on my game.  It is the orignal cab and all, so not sure what is going on. My cab looks like this:
Any other ideas/thoughts would be greta.  I would like it getting restored all the way to working.
Chris
arcadefever
  • Miami Beach Florida
Re: Outrun
« Reply #3 on: November 16, 2005, 10:33:38 pm »
i`ve this cab, the on and off swtich is on the right side on the bottom of the cab like metion early "lustreking" the switch is really small and he is on the side art not on the back of the cab.
this cab should have a motor shaker , look if it is no disconected , sometimes pepole turn them move (too much noise) check also all the conections on the board ....
coachcarstens
Re: Outrun
« Reply #4 on: November 16, 2005, 10:54:06 pm »
Well, I overcame my stupidity, I found the power button.   ::)  Sometimes, I surprise myself.   :-\  Now, to see if my motor is working, or better yet how to fix it.  I went to ebay, and i noticed many/almost all auctions there, they say that they have replaced the steering stuff ($50 value)  Are these things sold somewhere for $50?  Just curious.
arcadefever
Re: Outrun
« Reply #5 on: November 16, 2005, 11:39:53 pm »
i got one for $40 it is the same for after burner and because i have both cabs i got one in case.
you mabe wan to pull itoff and chek if it is working without the cab, could be a bad connection ....
also get the manual instruction this may help you too...
http://www.arcadedocs.com/vidmanuals/O/outrun_manual.pdf
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Outrun
« Reply #6 on: November 17, 2005, 12:02:30 pm »
Im confused. You powered it up... and.... does the wheel shake when you crash or not?
(You made it sound like you started browsing Ebay instead of testing the machine)
NO MORE!!
coachcarstens
Re: Outrun
« Reply #7 on: November 17, 2005, 03:24:07 pm »
Sorry for the confusion.  When you crash nothing happens.  After playing with the machine for awhile, I went to ebay to check out what they had on the site.  I saw auctions for the entire game, and many of the descriptions said they had just installed a new wheel pack.  Multiple auctions said it was a $50 valuse, so I was wondering about that.  I'm not even sure where you would buy this 50$ kit they talked about.
RayB
  • There's my post
    • RayB.com
Re: Outrun
« Reply #8 on: November 17, 2005, 04:36:11 pm »
Hmm, welp, we can help you. You need to post pics of the steering wheel guts. (You don't need to take it apart, just open up the control panel)...
Could be as simple as a broken belt or chain...
NO MORE!!
coachcarstens
Re: Outrun
« Reply #9 on: November 17, 2005, 05:24:11 pm »
Ok, I took a picture of the back of the control panel from inside the machine.  I hope this helps you guys by looking.
coachcarstens
Re: Outrun
« Reply #10 on: November 17, 2005, 10:09:40 pm »
Update:  My buddy and I were looking at this and testing some things out.  When you spin the motor is does create voltage, so most likely it is working.  However, when we follow the wires thoughout the machine, it is not plugged into anything.  So we have a dangling 6 pin molex with lock, where does this get plugged into.  Looking in the manual, there is no mention of a place to put it.  If anyone happend to have a picture of thiers, that would be great.  Otherwise, words are always good.
Looking at the manual, maybe we are missing 839-0048 SSR BD DC Motor  Controller
Any idea?
Chris
coachcarstens
Re: Outrun
« Reply #11 on: November 19, 2005, 07:15:43 pm »
Does anyone know of where you can buy old arcade parts?  I am definetly missing the part where the motor (and it appears) the cabinet fan plug into.  Does anyone know where you could buy this piece of the cabinet?  I have tried searching google and ebay.  It would definetly be something on the bottom of the machine.  However, the manual has seemingly no reference to this piece.
So, if you know where I could get one of these thing, please let me know.  I would be eternally grateful.
Chris
SuperGunGuru
  • Last login:December 10, 2021, 08:14:53 pm
  • Filling up that basement
Re: Outrun
« Reply #12 on: November 19, 2005, 08:55:32 pm »
« Last Edit: November 19, 2005, 09:04:48 pm by SuperGunGuru »
coachcarstens
Re: Outrun
« Reply #13 on: November 19, 2005, 11:18:56 pm »
Alright, here is a picture of the inside of my cab.  You will see the black line pointing to the connector of the motor (which is just dangling there), and a big black dot where something used to be so it could be plugged in.  There are a couple screw holes from something being there in the past.  I hope this is making sense to everyone.  I'm not really sure what the "part" looks like that should be there, but I'm hoping someone smarter than me around here does.
Thanks,
Chris
arcadefever
Re: Outrun
« Reply #14 on: November 20, 2005, 12:17:01 pm »
hi chris !
i`m not 100% sure but i think the part missing could be this one :
it is a small piece maybe 4" long max...
i`ve this cab and after burner and they both made by sega and both use a motor shaker. these piece work with the pcb and the motor shaker , every time you touch the grass or crash it send a signal for a few seconds to the motor and make the control panel move.
i'm at work but when i go home i will try to take a picture of the inside of my cab and i will let you know for sure if it is that part or not ....
and if it is !!! i've a few part as spair and wont mind to help you ...
fred
coachcarstens
Re: Outrun
« Reply #15 on: November 20, 2005, 12:21:21 pm »
That looks like it coulod be it.  I looked in my cab, and there is not a piece like that currently in there.  I'm practiclly shaking with excitement that you may have one, or even an extra.  I can't wait to hear from ya when you get back home.
Take Care,
Chris
arcadefever
Re: Outrun
« Reply #16 on: November 20, 2005, 12:23:31 pm »
ok the part missing maybe this one
(that a picture from after burner)
motor shaker ssr it is the same shape as the green one i post earlier but is brown instate of green
coachcarstens
Re: Outrun
« Reply #17 on: November 20, 2005, 12:26:58 pm »
yes, that does look very similar to the one you posted above.  :-)  So, how do I go about getting one of these (if you dont have extras)
Chris
arcadefever
Re: Outrun
« Reply #18 on: November 20, 2005, 12:27:07 pm »
i forgot that i post the pic on my web page
coachcarstens
Re: Outrun
« Reply #19 on: November 20, 2005, 12:32:56 pm »
What other piece do you thing I'm missing?  I'm looking at your picture, and I'm only seeing the borwn piece we have been talking about.  I seem to be able to match everything else up, but I'm not the most visually observant person in the world.
Chris
arcadefever
Re: Outrun
« Reply #20 on: November 20, 2005, 12:33:10 pm »
ok for sure it is that one !!!! look at the inside of your cab you can see a blue cable and a yellow cable disconected .. when you look at the afterburner that the same color that are conected to the brown pcb (yellow and blue)
and also that the 2 cables who are conected to mine
coachcarstens
Re: Outrun
« Reply #21 on: November 20, 2005, 12:36:50 pm »
I definetly see the piece!  YEA!  I'm pumped!  This has made my day...
Chris
arcadefever
Re: Outrun
« Reply #22 on: November 20, 2005, 12:45:23 pm »
cool i will get home a take a better picture and we will be able to see what else is missing or not .
i will get later with you an post the pic (around 9pm) tonight
fred
arcadefever
Re: Outrun
« Reply #23 on: November 20, 2005, 10:07:01 pm »
i've a very good news for you chris
arcadefever
Re: Outrun
« Reply #24 on: November 20, 2005, 10:10:55 pm »
here a closer look
in this little pcb you have 2 connection one with 2 cables and one with 4 i saw the one with the 2 in your cab , look if you have the one with 4
also i've the part you're missing , i tried it in my cab and it work perfectly , when i disconected the motor wasnt working , so that for sure what you need.
but first let me know if you can found the 4 cables conection coz you will need to plug that into the brown pcb ....
fred
coachcarstens
Re: Outrun
« Reply #25 on: November 20, 2005, 10:50:45 pm »
Outstanding.  I do thave the 4 wire plug, double checking, it is the plug i pointed out in the earlier pic above.  ALso, confirming my suspicions, you also plug the fan into this little brown thing, the 2 wire plug.  Those 2 plugs are the only two "loose" connections in the whole thing.
I seem to have everything else, even after a second look.   ;)
arcadefever
Re: Outrun
« Reply #26 on: November 20, 2005, 11:16:06 pm »
good,
the 4 wires strip go to that pcb and the 2 wire strip (blue and yellow) go also to that pcb
the fan should be plug from that pcb !!!!
ususally the fan run on 12v one wire to the 12c power supply and wire to gnd  !!!
coachcarstens
Re: Outrun
« Reply #27 on: November 20, 2005, 11:20:07 pm »
I think everything you just said was good, but I'm not totally sure.   :)
arcadefever
Re: Outrun
« Reply #28 on: November 20, 2005, 11:22:57 pm »
oops i mess up what i say  ::)
the fan shouldnt plug on that pcb .... :P
pm me your adress i will send that piece from work this week
fred
