Author Topic: Mamewah artwork fields  (Read 2631 times)
Xelotath
  • Last login:December 18, 2010, 11:07:44 pm
    • My Destructoid Blog
« on: November 12, 2005, 08:01:53 pm »
I formated my hard drive and didn't save my Mamewah folder, so I reinstalled it and everything works fine exept the artwork fields. #1 works but the other ones don't(I tried #2 to #5). I installed the system files and registered paintx.dll. Also in the layout the field emu name apears even if I disable it. I'll post my mame.ini file:
Code: [Select]
### mame.ini (mamewah v1.61) ###
emulator_title                            M.A.M.E.
### List Generation Settings ###
rom_path                                  c:\mame\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file                           c:\mame\catver.ini
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
emulator_executable                       c:\mame\mame.exe
commandline_format                        [name]{autodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]{autodosbox}{nosafelaunch}
alt_commandline_format_2                  [name]{autodosbox}{nosafelaunch}
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      c:\mame\snaps
artwork_2_image_path                      c:\mame\marquees
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path                        c:\mame\videos
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               0
saver_type                                movie
movie_path                                c:\mame\videos
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]{nodosbox}{nosafelaunch}
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
Thanks for reading.
« Last Edit: November 12, 2005, 11:26:32 pm by Xelotath »
drumlogix
  • Last login:April 25, 2006, 09:51:13 pm
  • MK-MAME Project.
Re: Mamewah artwork fields
« Reply #1 on: November 13, 2005, 11:45:06 am »
are you sure you have the folder names right? because in my mame folder its not "marqees" and "snaps" . its "snap" and "marqee" .. just a thought.
Xelotath
« Reply #2 on: November 13, 2005, 02:39:53 pm »
Yeah the folders are named ok, when I put the marquees in artwork #1 they show but in the other fields noting shows.
cdbrown
  • Bowowow
« Reply #3 on: November 13, 2005, 07:51:18 pm »
Have you rechecked the actual layout to see that it it's using the other artwork fields?  The default mamewah layout just uses the Artwork Image #1 only.  Perhaps the layout.lay file you created isn't the layout being used when you run mamewah.
### Misc Options ###
layout                      Classic 800x600
« Last Edit: November 13, 2005, 07:53:22 pm by cdbrown »
Xelotath
« Reply #4 on: November 13, 2005, 09:55:18 pm »
I tried with a layout I downloaded and it had artwork1 and 2 and I tried creating one and it has the same problem. I really don't know what is the problem...
On another note a cool feature for mamewah would be adding a Current Song for the fields you can add in the layout designer.
« Reply #5 on: November 14, 2005, 05:07:11 am »
I'm not sure, but since the Artwork #1 displays you obviously have all the system files installed OK.
All I can think of is what has already been suggested: check your layout has the correct artwork object #'s, and check the paths are correct  :-\
Xelotath
« Reply #6 on: November 14, 2005, 03:57:59 pm »
I can say I triple checked, tried to put them in low case and uper case and tried every artwork field and only #1 show up. Can the other fields display .png files?
« Reply #7 on: November 15, 2005, 05:27:41 am »
Yes.
Have you looked in mamewah.log to see if there is any indication there of what might be wrong?
Xelotath
« Reply #8 on: November 15, 2005, 03:32:13 pm »
I checked and I don't think there is a problem but i'll post a link to my mamewah.log:
http://rotdteam.sourceforge.net/mamewah.log I remember I had a similar problem for version 0.97 but never tried to fix it.
« Reply #9 on: November 16, 2005, 05:08:48 am »
Looks fine...
Strange but no-one else has mentioned the problem so it must be a configuration problem somewhere.
I suppose you could try the new beta version (from the Mamewah board) but to be honest it shouldn't make a lot of difference.
Xelotath
« Reply #10 on: November 17, 2005, 03:15:13 pm »
Yeah I'll try the beta and see what happens.
