Author Topic: Mamewah trackball question  (Read 2572 times)
kenmelk
  • Last login:February 08, 2008, 09:39:13 am
  • We live "In a world of PURE imagination"
« on: November 02, 2005, 11:20:55 pm »
I am using Mamewah (newest) and mame.  I have windows xp pro , athalon 1.2, 256m ram, and a 80 g HD.  I have a happs USB trackball that i want mame to use for games like centipede and missle comand, i have the mouse "on" in my INI and i still cannot use the trackball for these games,  the trackball works great as a mouse in windows so i know it works fine.  I also have a USB spinner that i want to use on Tempest iwith the same problems.  Again the spinner works in windows but i cannot get it to work in tempest as a controller, i only get the joystick to work.  thanks in advance,
Ken
GALAGA...a way of life!
diabolic
  • Last login:August 26, 2007, 02:36:22 pm
Re: Mamewah trackball question
« Reply #1 on: November 02, 2005, 11:28:04 pm »
Make sure you enable the mouse in mame.ini.  The Mamewah.ini settings aren't going to turn on the trackball inside of mame itself.
kenmelk
« Reply #2 on: November 03, 2005, 12:21:14 am »
i cannot find my mame.ini???  where teh heck is it?
ArcadEd
  • Last login:March 04, 2012, 01:25:15 am
  • Arcade-In-A-Box , Relive Your Childhood
    • Arcade-In-A-Box
« Reply #3 on: November 03, 2005, 12:27:59 am »
Should be in your mame directory.
If you are using mame32, there probably isn't a mame.ini, I don't have one.
Launch mame32 by itself and enable the mouse in the options menu, controllers, enable mouse input.
Then exit mame32 and launch through mamewah and see if it works
« Reply #4 on: November 03, 2005, 04:39:41 am »
If you don't have a mame.ini, create one using 'mame -cc' from a commandline.  Then ensure the following are set (in mame.ini):
dial_device             mouse
trackball_device        mouse
'mouse 1' will also work, but the above method is generally preferred.
kenmelk
« Reply #5 on: November 03, 2005, 07:21:07 am »
oh man i finally got it!   boy was that a chore~
Thanks guys for all your help.
