Author Topic: monitor compatibility  (Read 1622 times)
thegameguy
  • Last login:October 05, 2005, 09:09:21 am
« on: October 04, 2005, 09:45:53 pm »
Hello,
I have  a non working WG 19K4626 in a cabinet right now and I want to take it out - it was playing a horizontal game (super dodge ball, yea baby!!) - will it be compatible to put in a WG 19K4613 that I believe held swimmer (veritcal game) previously?
Basically, I guess what I am asking is - is it the pcb that determines the horizontal/vertical orientation of the screen, or is it the monitor itself? will this work w/out seeing things crooked? I want to still play super dodge bal, or another horizontal game.
Appreciate any input!! - Thanks!
Ken Layton
  • Guru
  • Technician
Re: monitor compatibility
« Reply #1 on: October 05, 2005, 01:14:26 am »
The gameboard determines the picture orientation (horizontal or vertical) on the screen of the monitor.
thegameguy
« Reply #2 on: October 05, 2005, 09:09:21 am »
ok -
so does that mean that I can put the working monitor into the cab and that it will play a horizontal game without being screwed up eventhough it was previously playing a vertical game?
Why is it then that the technician I bought the machine from told me that I would have to match the pcbs I buy and only play  games with that same monitor orienatation?
Jess--
  • Last login:April 05, 2023, 09:51:55 am
    • My Botched Cab
« Reply #3 on: October 05, 2005, 02:03:40 pm »
If you have a horizontal game you need your monitor Mounted Horizontally
If you have a vertical game you need to mount the monitor vertically
it could be that the monitor / cabinet combination you have does not allow the monitor to be rotated and that could be why the tech said you have to stick to one orientation.
