Author Topic: J-Pac help  (Read 1768 times)
dan57fina
  • Last login:April 23, 2006, 04:46:22 pm
  • Not bad for 14 years of age....
J-Pac help
« on: September 16, 2005, 07:31:04 pm »
Just installed computer into Jamma arcade cabinet, and have no idea how to install the monitor to the J-pac/ computer. I also do not know which buttons are concidered 4, 5 , and 6 for each player and audio hook up to cab speakers. Any diagram would be grately appreciated. Thanks for the help
-Dan
dan57fina
Re: J-Pac help
« Reply #1 on: September 17, 2005, 12:45:10 pm »
I guess doing things by yourself really is the way to go ;)
Harry Potter
  • Smite-bait
  • Last login:May 27, 2024, 03:33:28 am
  • Sober until banned. Can post but still can't read.
Re: J-Pac help
« Reply #2 on: September 17, 2005, 01:32:09 pm »
You could try the forum at Ultimarc. I hear Andy is quite prompt with his replies. Unlike the lazy no-good-for-nothing bludgers around here.  ;)
Now in a tasty new flavour.
Talon
  • Last login:January 16, 2007, 12:12:10 pm
Re: J-Pac help
« Reply #3 on: September 17, 2005, 05:04:59 pm »
Just set mine up in the last couple of days....
i just connected up one of the extra buttons up and then used the winipac util to check which button it was. In winipac there is a graphic view that shows you the basic layout of the buttons. I pressed all the buttons to check which extra one was working.If say the i pressed the 5th button and the 6th button lit up on the winipac program then i moved the wire to the 6th input slot on the JPAc. I did the same for the rest.
As far as connecting the monitor. it depends which monitor you have, arcade/computer?
the JPAC has all the lables on it. Guess thats why you have not had alot of replies ;)
hope this makes sense :o
SirPeale
  • Green Mountain Man
Re: J-Pac help
« Reply #4 on: September 17, 2005, 05:17:39 pm »
The J-PAC is designed to plug-and-play right into a JAMMA cabinet.  About the only connecting you should have to do on an existing JAMMA cabinet is for the speaker, and that is clearly labeled.
As for buttons 4, 5 and 6 it's just a matter of having your grounds set (which should already be done with the ground loop) and then running a wire from each connection on the J-PAC to each button.
Level42
Re: J-Pac help
« Reply #5 on: September 19, 2005, 10:05:36 am »
http://www.ultimarc.com/jpac2.html
And READ ;)
And there's plenty more where that came from ;)
