Author Topic: Isolation Transformer Connector for WG4600?  (Read 1704 times)
TurboC--
  • Last login:December 21, 2023, 12:23:05 am
  • No one can defeat the quad laser!
« on: September 15, 2005, 05:57:23 pm »
I received my isolation transformer today (quite hefty!), which simply has 4 terminals (2 'Primary' and 2 'Secondary'), and no wires or connectors at all.  My WG monitor has a 2-pin white plastic connector for the power input, which looks pretty standard.  I was hoping the transformer would come with some kind of standard connector, but nothing doing.  What's the best/safest way to jack this thing into my monitor?  Hack up a regular power cord, chop off the 2-pin connector on my monitor, and splice it in?   ::)  Get a hold of the other end of this WG 2-pin connector somehow?
Ken Layton
  • Guru
  • Technician
Re: Isolation Transformer Connector for WG4600?
« Reply #1 on: September 15, 2005, 06:09:27 pm »
The correct mating connector you need is Molex # 19-09-1029 Two pin white housing and either #02-09-1101 pins or 02-09-1116 pins.
« Last Edit: September 17, 2005, 12:30:51 am by Ken Layton »
SirPeale
  • Green Mountain Man
« Reply #2 on: September 16, 2005, 06:42:55 am »
You may be able to order some free samples from Molex themselves.  I've done it in the past.
TurboC--
« Reply #3 on: September 16, 2005, 12:03:29 pm »
I looked up the product numbers you mentioned on molex.com.  The first looks like a 3x3 block of connectors.  The second is I guess the metal pin that goes into the housing.  So I'd be using a generic 9-pin block and only using 2 of the pins?  Well, if I'm doing THAT, maybe I can just use some of the stuff I already have.  There's some adapters leftover in my cab for connections I am not using, maybe one would fit the monitor connector...
