Author Topic: 39-in-1 multi pcb  (Read 3162 times)
pogo
  • Last login:March 25, 2026, 10:34:41 am
39-in-1 multi pcb
« on: September 04, 2005, 01:02:03 am »
I'm looking at buying either the 39-in-1 pcb or the arcadeshop programmable pcb.  I read that Ms Pac-Man and Galaga have joystick timing issues, especially when Ms Pac-Man is set to fast mode.  Does anyone know if the 39-in-1 control issues have been fixed in the latest boards?
I would prefer to go ahead and purchase the arcadeshop pcb but my wife wants Ms Pac-Man to be set to fast mode and it doesn't appear that the arcadeshop pcb will do it.
ARCADE5280
  • Last login:June 19, 2007, 04:01:40 pm
Re: 39-in-1 multi pcb
« Reply #1 on: September 04, 2005, 01:30:39 am »
The arcade shop board will play both regular and fast.
pogo
« Reply #2 on: September 04, 2005, 01:38:38 am »
Thanks.  Looks like I'll be buying the arcadeshop pcb.
albrigsr
  • Last login:July 29, 2016, 09:24:49 am
« Reply #3 on: September 04, 2005, 12:08:14 pm »
Exactly how do these boards work?  It looks like I could plug in a Computer monitor and then it has a jamma board?  Is there some sort of connector for the jamma boards that I could use to hook up controls?  I am asking because I would be interested if I can just buy one of these, hook up a computer monitor and then wire up my controls?  Is it that simple (it seems like I would at least need some sort of connector for the fingerboard unless I learn to solder....which I won't!).
ARCADE5280
« Reply #4 on: September 04, 2005, 02:53:49 pm »
You can always get a complete JAMMA wiring harness.
pogo
« Reply #5 on: September 04, 2005, 11:47:53 pm »
You need a jamma wired arcade cabinet.  You can't use a computer monitor.  You would need a power supply, jamma harness, arcade monitor, and a jamma pcb if you were going to wire the cabinet yourself.
Jon L.
  • Last login:October 17, 2005, 02:39:46 am
  • Music & Dance machines, spare parts, upgrade kits.
    • Channelbeat.com
« Reply #6 on: September 05, 2005, 04:46:21 am »
Just plug the PCB into the normal Jamma cabinet's Jamma harness then it will work. A Jamma cabinet will come with the Arcade monitor + chassis which is difference with TV or PC monitor.
paigeoliver
  • Awesome face!
« Reply #7 on: September 05, 2005, 05:37:16 am »
I don't want to confuse any issues, but some of the multi-boards do indeed also have a VGA output in addition to the CGA one.
