March 18, 2026, 01:20:28 pm
How will you make it spring back to center? I'd imagine the springs in the thumbstick itself are nowhere near strong enough.
the thumbsticks use a combination of two potentiometers each, giving it dual axis analog capabilities.... so in other words, it doesnt use switches. The only way to use an arcade joystick would be to connect it to the digital pad.
