Author Topic: X-Arcade solo with mamewah  (Read 1016 times)
kevinchall
  • Newbie
  • Last login:August 29, 2005, 11:52:56 am
« on: August 29, 2005, 11:52:05 am »
This is probably been beat to death but I have been through the posts several times and seem to be getting more confused.  How do I set up the xarcade controller.  Do I set it up once in mamewah? Once for each emulator? Or do I have to for each game?  I know there is supposed to be support for this controller in the emulators.
I am building a cabinet for my son for his birthday next month and need to figure this thing stuff out.
If anyone can help or just direct me to a novice post it would be appreciated.
I will try to set up from scratch tonight using mamewah config but I am not sure if it goes into the controller set up or not.
Thanks to all for your help.
Re: X-Arcade solo with mamewah
« Reply #1 on: August 30, 2005, 06:14:08 am »
You need to setup everything you want to use the controller with.  For Mamewah, this means editing \ctrlr\default.ini (you need to map num.pad keys instead of arrows) - see \docs\ctrlr.txt for help.
For MAME you need to set 'ctrlr xarcade' in your \mame\mame.ini file. For other emulators chances are you'll need to setup the keys manually.
