Author Topic: What size is my WG monitor?  (Read 2347 times)
lettuce
  • Make It So!
« on: August 22, 2005, 12:45:18 pm »
I have a Well-Gardner K7000 monitor, now i was under the impression that it was a 25" screen, but i measured the screen the other day, from top right to bottm left, and the measurement i got was just over 26 and a half inches (68cm)!!!. How is this, i thought 25" was the largest size they did in this model, and i know they dont do half inch measurements, or 26" screens infact. So what size monitor do i have??
TurboC--
  • Last login:December 21, 2023, 12:23:05 am
  • No one can defeat the quad laser!
Re: What size is my WG monitor?
« Reply #1 on: August 22, 2005, 01:00:58 pm »
My 19" WG says 19K4616 on its sticker.  Do you see a 2 digit number preceeding the K?  Maybe that would be your size.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #2 on: August 22, 2005, 06:07:13 pm »
Viewable area.
Not tube size.
I.e. a 27" american monitor is called a 29" in japan because they measure the tube size instead of the viewable area.
Later,
dabone
Ken Layton
  • Guru
  • Technician
« Reply #3 on: August 22, 2005, 06:31:27 pm »
The first two digits on the model number sticker is the screen size. There were a few 27" k7000's made. Look also at the numbers on the picture tube. If it starts out "A63....." it's a 25" tube. If it starts out with "A68......" it's a 27".
lettuce
  • Make It So!
« Reply #4 on: August 23, 2005, 01:26:39 pm »
I cant seem to find the model number sticker, but the sticker on the picture tube has a number on it,
G-A63ADG25X
04RC010J-007
dabone
  • Time to work...
« Reply #5 on: August 23, 2005, 02:58:28 pm »
25" it is.
Later,
dabone
Ken Layton
  • Guru
  • Technician
« Reply #6 on: August 23, 2005, 05:38:58 pm »
Yup the A63 in the tube number confirms it. You have a 25" tube.
lettuce
  • Make It So!
« Reply #7 on: August 24, 2005, 01:59:43 pm »
OK thanks, is this monitor CGA, EGA, or VGA?
dabone
  • Time to work...
« Reply #8 on: August 24, 2005, 02:49:14 pm »
CGA, 15k standard resolution.
Later,
dabone
