Author Topic: Audiophiles, Need Suggestions Please...  (Read 7141 times)
pointdablame
  • Last login:May 19, 2025, 06:36:30 pm
Re: Audiophiles, Need Suggestions Please...
« Reply #40 on: August 25, 2005, 12:30:24 pm »
Naturally, you don't want to have that friend over anymore. Especially after you've lifted his audio system.
Hey, I see you upgraded all your equipment to the stuff *I* used to have...
Hey, that scratch in your amp is exactly the same as the scratch in *my* former amp...
ScoopKW
yup... that situation would NOT end well haha
first off your and idiot
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #41 on: August 26, 2005, 10:43:59 am »
PS -- Silverwind -- I just looked at GR Audio, and I'd pass. They don't tell you what's in the crossover, nor the crossover schematics. They only mention response levels. I'd go to www.madisound.com and look at the Audax AV kit if that's what you're into. Prices are about the same, and you'll *probably* get better sound. (There are no substitutes for hooking both sets to your system and testing them. Usually, that's too cost inefficient.)
EDIT -- Added the above advice for Silverwind.
The components are:
Alpha Core foil inductors, Links resistors, Axon caps with Sonicap by-pass
caps, and there is a Sonicap upgrade available.
And you put them together yourself, they send a diagram with them when you purchase.  I searched high and low and could not find any negative comments on them.
ScoopKW
  • Last login:August 06, 2006, 08:32:53 pm
  • Stage one complete, pix coming
« Reply #42 on: August 26, 2005, 08:10:24 pm »
Hmm... I didn't find that on the site.
Those are certainly good components. And I'm sure they're properly matched to the drivers, so no worries...
ScoopKW
