Author Topic: Communication problem with I-Pac and keyboard  (Read 1952 times)
motorfish
  • Last login:September 30, 2009, 03:35:08 am
« on: August 16, 2005, 02:29:14 pm »
Hey all. Here's the scoop:
I have a new Athlon64 that I've replaced my old P4 with. For whatever reason, I can't get the Athlon to recognize the keyboard when channeled through the I-Pac in either Serial or USB mode, regardless of the jumper settings on the I-Pac. I've tried the keyboard directly into the PC, so I know the keyboard is working.
For the OS, I'm using Windows XP.
Any ideas? Do I need to post more information?
- Dan
Have you paid your dues Jack?......Yessir, the check is in the mail!
motorfish
Re: Communication problem with I-Pac and keyboard
« Reply #1 on: August 17, 2005, 01:30:15 am »
Rats. 17 views and no hits.
- Dan
2600
« Reply #2 on: August 17, 2005, 09:02:54 am »
I'll bite, but probably be less then usefull.
Normal I-PAC?
When you say serial you mean PS/2?
You plug everything in, the keyboard is in the correct spot on the I-PAC, turn on the PC, open up notepad, type on the keyboard, and get nothing?
Does the I-PAC work without the keyboard?
Does it still work with the keyboard plugged in?
motorfish
« Reply #3 on: August 17, 2005, 07:38:19 pm »
Hmmm...upon further investigation, it looks like the PC that was previously attached to this I-Pac took the I-Pac with it when the Motherboard fried...
The PC will boot with a different I-Pac, so at least I've isolated the problem down to the I-Pac, rather than the computer.
Bummer...this I-Pac 4 was almost brand new....
- Dan
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #4 on: August 18, 2005, 12:35:35 am »
I wonder if it is fixable :(
sorry to hear about the I-pac.  do you see any burn marks on it?
Dagg
  • Last login:June 05, 2017, 04:23:59 pm
« Reply #5 on: August 18, 2005, 08:27:23 am »
I had this problem but it was a USB keyboard, putting it in the USB port under the actual normal keyboard input worked for me.
