Author Topic: 'OK' Screens - yes, i searched!  (Read 1962 times)
cid499
  • Last login:October 11, 2006, 07:32:30 pm
« on: August 13, 2005, 02:10:25 am »
Hey all,
I am having a problem getting past the MAME 'OK' screens without using a keyboard. I have already disabled most of them, but still can't get past the few that do show up without scrambling for my keybord. I  use a keyboard hack and have P1 Joystick Left set to F7, and P1 Joystick Right set to 'O.' UI_LEFT and UI_RIGHT are configured the same (F7, O).
But the joystick wiggle doesn't work.
Maybe F7 is a special button that shouldn't have been programmed to the P1 joystick. But I went through the mame.ini and remapped all keys that use F7, so there shouldn't be any intereference.
Any ideas?
donjuanzx9
  • Last login:November 13, 2008, 03:00:28 am
  • NATURAL BORN GAMER!
    • go to rom-forum
Re: 'OK' Screens - yes, i searched!
« Reply #1 on: August 13, 2005, 03:15:39 am »
newest mame32 lets you wiggle your joystick from left to right to do ok you might try remapping and doing this,or do what I do use a wirless keyboard and mouse.works great and no fuss.
« Last Edit: August 13, 2005, 03:20:25 am by donjuanzx9 »
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« Reply #2 on: August 13, 2005, 07:44:13 am »
It is the most common question that new mame users often ask. :)
I don't know which version of mame/mame32 you are using,but
check your emulator specific INI file such as mame.ini
set.
skip_disclaimer         0   to 1
skip_gameinfo          0   to 1
Your keyboard hack for player1 joystick should be work with F7.
I suggest to to avoid those functional Keys like F7 and Ctrl,Alt,Shift.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: August 13, 2005, 10:26:24 am »
Can you play the game with your keyboard, not hte hack, with those settings?
F7 is save state by default in mame.
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: August 13, 2005, 10:35:28 am »
cid499
« Reply #5 on: August 13, 2005, 03:24:22 pm »
I did this, but the OK screen still shows up in 'broken' games.
Yes, I can play. Any feature that requires F7 has been mapped to something else.
cid499
« Reply #6 on: August 13, 2005, 03:27:55 pm »
Thanks Tiger-heli for the link. Recompiling mame seems to be the best solution for me.
And thanks for the KB hack guide too.
