Author Topic: help me put a wells gardner into a sony tube  (Read 2293 times)
alundra
  • Last login:February 02, 2009, 09:30:05 pm
« on: July 31, 2005, 03:47:35 pm »
ive heard you can put a arcade chasis into a tv tube, so i want to know if i can put my 25" WG chassis into my 27" Sony tube? i need to replace my monitor, it got too many burn in..how can i do this, is there a guide for this? thanks
alundra
Re: help me put a wells gardner into a sony tube
« Reply #1 on: July 31, 2005, 06:47:07 pm »
can someone even tell me what should i do, i did alot of search on this forum but cant find any specific info how to swap tube..the most worth info i can find is that someone mentioned the tv tube have to be compatible with chassis by measure the ohms on the vertical and horizontal..i have no idea how to do this, someone mentioned there is a step by step how to do this in here, but i cant find it  ???..can someone point out the thread for me..thanks
alundra
« Reply #2 on: August 01, 2005, 12:07:28 am »
Ken can probably confirm, but Sony Trinitron tubes are totally unlike/incompatible with all other standard shadow-mask tubes. Even if it is electrically compatible, at the very least you will have significant geometric distortion as Trinitron tubes are flat vertically and only curve horizontally. I would NOT suggest attempting to swap in a Trinitron tube into an arcade chassis.
There are numerous tube swapping web sites.. Use Google and search for "arcade tube swap"  I turned up numerous good links on the first page of results alone.
Again however, you have to ensure many things match before you swap a tube:
1) The pinouts on the tube are identical (need to have good reference books or be able to trace circuit boards)
2) The size/power requirements of the tube are within the same range (e.g. a 27" tube will not work on a 13" or 20" chassis and may not work on a 25")
3) The deflection angle of the tube
4) The impedence and/or dc resitance of the yoke attached to it
Some of the above items are critical safety/immediate circuit damage issues, while others are simply geometric imperfections from minimal to totally unacceptable.  Again, a Trinitron tube is a different beast. I wouldn't waste my time.
can you explain or give example of number 3 and 4? and for number 1, you mean like if the arcade chassis have 10 pins, that mean i have to get a 10 pins monitor? is that right? thanks
Ken Layton
  • Guru
  • Technician
« Reply #3 on: August 01, 2005, 01:05:53 am »
Sony picture tubes are completely different internally than other brands of picture tubes. They are NOT compatible at all with any other chassis except another Sony chassis.
Try this tube swap link:
http://coinop.org/repair/Monitor_Tubeswap.aspx
alundra
« Reply #4 on: August 01, 2005, 01:19:05 am »
anyone know any tv brand tube that will compatible with a 25" WG 25k7139? this will save me lot of time for looking for a compatible  tube...
alundra
« Reply #5 on: August 02, 2005, 03:49:11 pm »
can you help me find that BK link that you mentioned above..cause i cant find it...
