Author Topic: DK JR PCB (monitor related)  (Read 3493 times)
sp0rk
  • Last login:August 30, 2007, 04:40:42 pm
« on: July 20, 2005, 02:44:10 pm »
I'm posting this in here, because I'm not sure if it's a monitor issue or not.
« Last Edit: August 02, 2005, 09:26:05 am by sp0rk »
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
Re: dj JR PCB (monitor related)
« Reply #1 on: July 20, 2005, 03:33:29 pm »
You probably have one or both of the screen adjustment pots on the Video board broken.  We sell replacments.
http://www.mikesarcade.com/cgi-bin/store.pl?sku=POT30K
Best,
 - Mike -
sp0rk
« Reply #2 on: August 01, 2005, 10:21:47 am »
I replaced the pots.  Still get the same problem.  Not sure what is causing it.  I can see parts of the screen sometimes, and when I move the pots, I can see parts of the screen moving horiz/vertically.
Any help?  I included pictures of the adapter, pots (replaced) and what the screen looks like.  Thanks!
http://www.rimuldar.com/dkjr/adapter.jpg
http://www.rimuldar.com/dkjr/pots.jpg
http://www.rimuldar.com/dkjr/screen.jpg
pcb
    • MikesArcade.com
Re: DK JR PCB (monitor related)
« Reply #3 on: August 02, 2005, 03:50:54 pm »
Try adjusting the Horizontal Hold on the monitor.
« Last Edit: August 02, 2005, 03:52:32 pm by pcb »
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« Reply #4 on: August 23, 2005, 09:38:45 pm »
if you havent fixed this yet it looks to me as the sync on the monitor maybe in the wrong location or not hooked up...also the horizontal hold maybe out of whack...but i would vberify the h and v sync are setup correctly
pcb
    • MikesArcade.com
« Reply #5 on: August 24, 2005, 12:19:45 am »
Remember Nintendo games output NEGATIVE video signals, not POSITIVE.
Right, I hear it referred to as inverted video too.  Anyway, the adapter he's using (one of mine) already takes care of the color correction and the sound amp.
Best,
 - Mike -
sp0rk
« Reply #6 on: August 24, 2005, 02:24:13 am »
It was the horizontal hold.
The monitor I was testing it out on still can't get a decent picture.  (its a wells, can't remember what model).
I hooked it up to an electrohome in my other jamma cab, picture came out perfect.  Not sure why the other monitor can't get a clear signal in, but the problem is fixed for now.  I just need to move the shelf mount bracket off the electrohome and put a vertical metal mount so I can get it in the cabinet without sticking out the back.
Thanks for your help guys.
 (ps, on an unrelated note, I have a mario brothers board that works great, but has a constant high hissing sound through the speakers when I do anything except walk [when I walk it goes away] Just thought I'd ask, since I see mike posted to this, and was wondering if you had any idea what it could be? Thanks again for the help!)
pcb
    • MikesArcade.com
« Reply #7 on: August 25, 2005, 12:59:46 am »
Hmm, I'd have to see the board, but it could be a bad cap, transistor or even the sound cpu.  Have you tried removing the sound cpu to see if it goes away?
 - Mike -
