Author Topic: Kaga Denshi Flyback  (Read 3389 times)
Wetworks
  • Last login:December 16, 2017, 11:27:10 pm
  • Look Mum I glow!
Kaga Denshi Flyback
« on: July 20, 2005, 08:34:04 am »
Started cleaning up my Donkey Kong cocktail today. I hadn't turned it on in quite a while. The monitor and everything worked the last time I tried it but there was no picture when I fired it up this time??. The fan, sound and controls are all working so the board is ok. There is no orange glow in the yoke so there was is power getting there. After a few seconds there was a waxy burning smell appearing faintly and I think it was coming from the flyback transformer.
1. Does this sound right? The one for this board ( Kaga Denshi and the monitor is a mitsubishi 20") is seperate from the chassis. See photo.   2. Could it be anything else?
3. Do these Flyback transformers just go?
4. Can you fix them or where is the best place to buy them as this one seems a bit rare and finding any info on the chassis is hard.
5. I f someone does know of it can you get a cap kit for it?
6. Should I just invest in a new one?
Thanks for any help
Ken Layton
  • Guru
  • Technician
Re: Kaga Denshi Flyback
« Reply #1 on: July 20, 2005, 10:18:19 am »
nwhutt
  • Last login:July 31, 2005, 05:53:58 am
« Reply #2 on: July 20, 2005, 04:20:17 pm »
It might also be worth contacting John Power; arcade80s@bigpond.com.  I know he has modified some kaga boards to use a Kortek EHT which is still available.
Wetworks
  • Look Mum I glow!
« Reply #3 on: July 20, 2005, 08:06:45 pm »
Thanks I will contact Jomac today. Appreciate the quick reply!  :)
Wetworks
  • Look Mum I glow!
« Reply #4 on: July 21, 2005, 02:26:06 am »
Well spoke to Jo today about the Kaga Denshi board and Flybacks for this are virtually nonexistent
« Last Edit: July 21, 2005, 02:29:04 am by Wetworks »
nwhutt
« Reply #5 on: July 21, 2005, 03:48:35 pm »
Don't expect to get great things from the Jen Shinn chassis, some people have had great results from it, others haven't.  I have one of these on a 21" monitor in my Space Harrier Sim, although it has got me going again it is nowhere near what I was expecting.  Comparing it to the original Nanao chassis it is a poor substitute.  This could be down to a numerous amount of different reasons perhaps it just doesn't like my tube.  What I have found is the picture goes dark on bright scenes and it's really hard to get it sharply focused across the whole screen.  Oh and when the picture goes dark the colours go slightly wacko as well which is a little annoying.  I have put this down to it having a weak power supply I had to turn the B+ right up just to get a usable picture and the chassis just about manages to put out about 22-23kv of EHT, this should be nearer 25kv.  The EHT also sags a little on bright scenes which would explain why the picture is going dark.  In my opinion if the power supply on this was stronger it would probably be the ultimate universal chassis, as apart from it's shortcomings it does work quite well, geometry etc is good and it doesn't need an iso transformer you can stuff it straight into the mains, anything from around 90v to 240v.
