Author Topic: Removing an arcade monitor's mainboard...PICS INSIDE  (Read 2950 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: July 09, 2005, 11:38:10 am »
blue colour keeps going from the display on my arcade monitor (see my other post).
« Last Edit: July 12, 2005, 04:46:31 am by eggedd2k »
tristan
  • Last login:October 07, 2022, 05:37:32 pm
  • I have no idea what's going on
    • Nothing
Re: Removing an arcade monitor's mainboard...safe to do??
« Reply #1 on: July 09, 2005, 12:23:49 pm »
If you would have to remove the anode cap from the tube (suction cup with red wire) to get the board out, you would have to discharge the tube first.
eggedd2k
« Reply #2 on: July 10, 2005, 07:11:03 am »
it looks like it'll just unscrew actually - dont think the cap needs to come off as well
Ken Layton
  • Guru
  • Technician
« Reply #3 on: July 10, 2005, 11:59:16 am »
Most of the time the monitor main board will unbolt easily to slide out just enough to flip it over to look at it/work on it. Make sure the monitor is unplugged from power. Sometimes you need to unplug the degausser coil and/or the yoke connector to allow the board to slide out enough to work on.
eggedd2k
« Reply #4 on: July 12, 2005, 04:46:11 am »
i've taken a photo of the monitor's board.  Can anyone easily tell if removing it will be easy and safe?
i've put some arrows on indicating screws and a plug connector - also an arrow for a potential danger spot.
if anyone could verify removal details that'd be great.
eggedd2k
Re: Removing an arcade monitor's mainboard...PICS INSIDE
« Reply #5 on: July 12, 2005, 08:29:23 am »
are there likely to be any visual signs that the soldering has cracked??
Ken Layton
  • Guru
  • Technician
« Reply #6 on: July 12, 2005, 10:22:48 am »
Sometimes yes and sometimes no. I resolder the pins anyway.
eggedd2k
« Reply #7 on: July 12, 2005, 10:38:23 am »
what about safety issues of removing the board?? what if flipping the board over causes tothe board touch the stuff above it?
nwhutt
  • Last login:July 31, 2005, 05:53:58 am
« Reply #8 on: July 18, 2005, 03:50:15 pm »
You should be fine, just be careful and treat the monitor with respect.  You will most likely need to unplug the yoke and the degauss coil, then remove the 2 screws and flip the PCB over.  You will then be able to resolder the connectors on the RGB input header.
eggedd2k
« Reply #9 on: July 18, 2005, 04:08:35 pm »
which are the danger points on the photo above - any chance you could arrow them?
Karetaker
  • Last login:July 28, 2022, 08:19:40 pm
« Reply #10 on: July 18, 2005, 07:34:10 pm »
You should discharge the monitor even if you are not pulling the anode off. It's just a precaution that only takes a moment to do.
