Author Topic: ArcadeVGA card not compatible with AGP on my computer!!  (Read 2187 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: June 28, 2005, 09:43:01 am »
can't believe it - means i've gotta get a new mb and processor now!
8 beeps when i switch on with the card inserted. tried on two identical computers.
AlanS17
    • AlanS17
Re: ArcadeVGA card not compatible with AGP on my computer!!
« Reply #1 on: June 28, 2005, 06:05:07 pm »
What sort of computer?
StephenH
« Reply #2 on: June 28, 2005, 10:05:53 pm »
Some things I would check:
1) Check in the BIOS using a standard video card, and make sure the AGP options are set correctly, and disable any on-board video.    Then, reinstall ArcadeVGA and see if it works.
2) Try updating to the latest BIOS for your model computer
3) The ArcadeVGA card could be defective.  I would try calling Ultimarc to see if they would exchange it.
4)  Go to the tech support for your motherboard, and look up the meaning of the 8-beep code.  Be sure to note any pauses, or if any beeps are longer or a different tone than others.
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #3 on: June 29, 2005, 05:37:34 pm »
Very good advice there.
-Ace-
I want my own arcade controls!
AlanS17
    • AlanS17
« Reply #4 on: June 29, 2005, 06:04:03 pm »
Do you have a newer or older ArcadeVGA?
How old is the computer?
eggedd2k
« Reply #5 on: June 30, 2005, 03:37:43 am »
done all that already. the computer is a good 3 years old.  the arcadevga is new and ultimarc have tested it their end and works fine.  the two computers that i have that have agp slots were identical and it didnt work on either.
AlanS17
    • AlanS17
« Reply #6 on: June 30, 2005, 06:18:58 pm »
What's the speed of the AGP slot on the PC? What's the speed of the video card?
tristan
  • Last login:October 07, 2022, 05:37:32 pm
  • I have no idea what's going on
    • Nothing
« Reply #7 on: July 05, 2005, 09:22:18 pm »
What size is your power supply? Newer cards generally use more power, and manufacturers tend to use the smallest power supply they can get away with.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #8 on: July 05, 2005, 10:46:04 pm »
What computer and or motherboard are you using.
And chipset of the motherboard if you know it.
Also, is the arcade vga the one with 1 or 2 vga ports on it?
Later,
dabone
