Author Topic: Stargate project...  (Read 4172 times)
Rook3
  • Last login:August 07, 2025, 01:40:55 am
  • Greetings Starfighter! You have been recruited...
    • Rook's Castle.com
Stargate project...
« on: June 26, 2005, 11:43:15 pm »
Due to inspiration started by the Moon Patrol project, I've decided to
try reclaiming a bastardized Stargate.
Used "Goof Off 2" to start stripping the old paint. Sprayed the cabinet down, let it sit for 5-10 minutes then used a plastic putty knife to remove the first layer.
Tried using a nylon scrub brush on the first layer but all it did was, well, remove the top layer.
« Last Edit: June 26, 2005, 11:45:18 pm by Rook3 »
SuperGunGuru
  • Last login:December 10, 2021, 08:14:53 pm
  • Filling up that basement
Re: Stargate project...
« Reply #1 on: June 26, 2005, 11:51:17 pm »
Cool stuff! Always nice to see the old artwork being uncovered on a cab.  :) Good luck with the resto.
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« Reply #2 on: June 27, 2005, 10:22:41 am »
Nice work keep it up.
Curls in the squat rack !?!?!
Rook3
    • Rook's Castle.com
« Reply #3 on: June 27, 2005, 10:32:03 am »
Thanks guys. Does anyone have Williams paint codes for Stargate? I'm certainly going to need to repaint/touch up the art in places and I'd like to get as close as possible to the original colors. I checked out one site, but he had codes for a lot of other Williams cabs, just not Stargate.
Rook
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
« Reply #4 on: June 27, 2005, 01:57:56 pm »
Rook3
    • Rook's Castle.com
« Reply #5 on: June 27, 2005, 07:49:25 pm »
Thanks for the link! That's not the site I'd visited before so between the two I should be covered!
Thanks again,
Rook
pcb
    • MikesArcade.com
« Reply #6 on: June 29, 2005, 12:18:52 am »
My Pleasure.  FYI, the first Stargate I one I did.  Cut out the stencils by hand and took about 1 month to trace, cut and finally get the cabinet painted.
Good luck!
Rook3
    • Rook's Castle.com
« Reply #7 on: June 30, 2005, 08:35:14 pm »
What did you use to make your stencils?
Rook
pcb
    • MikesArcade.com
« Reply #8 on: July 10, 2005, 02:42:39 pm »
I used large sheets of picture matting from Aaron Brothers.
 - Mike -
Rook3
    • Rook's Castle.com
« Reply #9 on: July 10, 2005, 07:48:37 pm »
I was at a huge arts/crafts store on Firday (Wife HAD to stop. Matter of life or death or so she said... probably mine. ;) ) and they had some plastic stencil material. I picked up 5 pieces for $1.50 a piece. I SHOULD have enough to do the whole cabinet. I'm hoping that all the graphics mirror (easy flip of the stencil) aside from the stargate title, which does not.
Have to wait and see. I plan on at least partially stripping the other side so I can use the original graphics as a template.
Rook
pcb
    • MikesArcade.com
« Reply #10 on: July 11, 2005, 12:02:58 pm »
Yes, if you do them right, the black might flip.
« Last Edit: July 11, 2005, 12:47:51 pm by pcb »
