Author Topic: do i need to add buttons?  (Read 2533 times)
joshbr7257
  • Last login:August 15, 2006, 10:12:28 pm
  • B.Y.O.B.!!!!!!!!!!!
« on: June 18, 2005, 03:39:08 am »
im making a two person cp and so far i was using6 buttons for each player 1 player start button for both, and 2 insert coin buttons, but i see other peoples cps and they have 2 more? for what?
oh i just saw someones labeled cp are they for pause and quit game?
if so how do i put pause and quit game on mine if im using a I-PAC2?
« Last Edit: June 18, 2005, 03:53:20 am by joshbr7257 »
WANT A FREE PSP? CLICK BELOW.
http://www.FreePSPs.com/?r=17776949
flampoo
  • Last login:March 20, 2014, 11:41:07 am
  • BYObsession
    • flampoo
Re: do i need to add buttons?
« Reply #1 on: June 18, 2005, 08:52:10 am »
Yes, the extra two buttons are typically for pause and escape. But you don't have to have them on the cp - you can hide them. You should have rec'd some instructions w/ your IPAC that gives you a key configuration. Each input has a default keystroke. Use them accordingly.
grueinthebox
  • Last login:February 07, 2014, 12:37:03 pm
  • Feed your head.
    • red42.com
« Reply #2 on: June 18, 2005, 01:23:44 pm »
Default for MAME with an IPAC would be P1 Start + P2 Start for ESC, P1 Start + P1 joystick down for Pause.  I like the shifted commands much better than a bunch of admin buttons, since you wouldn't find them on a real arcade machine, but YMMV.
"All right. It's Saturday night. I've got no date, a two liter bottle of Shasta, and my all Rush mix tape. Let's rock!"
joshbr7257
« Reply #3 on: June 18, 2005, 06:45:29 pm »
wow that is cool is it easy to set up your I-PAC to do that?
grueinthebox
  • Feed your head.
    • red42.com
« Reply #4 on: June 18, 2005, 07:29:31 pm »
Should be set up to do that out of the box.
Here we go...  Default mappings for an I-PAC:
« Last Edit: June 18, 2005, 07:33:37 pm by grueinthebox »
joshbr7257
« Reply #5 on: June 18, 2005, 07:42:58 pm »
but then how do you set it up so u can pause the game like hold 1 playerstart and press down on the joystick, i dont se that on the chart
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
« Reply #6 on: June 18, 2005, 08:04:57 pm »
You use the IPAC programming utility that comes with the IPAC.
That chart is a custom one made by grueinthebox (great screen name, BTW!), but it shows the default mappings nicely.
For more information on the IPAC, check out the Ultimarc site -- the answers to most of the questions you've been asking in various threads are actually contained in the information there.
-- Chris
Underway: Joey's Arcade
joshbr7257
« Reply #7 on: June 18, 2005, 08:40:21 pm »
ok thanks i will
grueinthebox
  • Feed your head.
    • red42.com
« Reply #8 on: June 18, 2005, 09:04:46 pm »
Just for the record, I didn't make the graphic - I think it came from the website in the lower right corner of the image...  I've had it kicking around so long, I can't be sure.  Don't want to take credit for others' work - I just scaled it down and am passing it along.
But you shouldn't have to use the programming utility to set up the pause and whatnot - if you look at the chart there, pause ('P') is in blue under the P1 down...  Things in blue are accessed by using that control while holding the P1 start key.
CJK
« Reply #9 on: June 19, 2005, 07:10:43 am »
True -- the pause function is set up the way you describe as the default on the IPAC, so you don't need the programming utility unless you want to change something. But who doesn't want to change something?  :)
-- Chris
