Author Topic: mamewah game names  (Read 4835 times)
dan57fina
  • Last login:April 23, 2006, 04:46:22 pm
  • Not bad for 14 years of age....
mamewah game names
« on: June 10, 2005, 03:41:36 pm »
is there any way to change mamewah so that it reads the game name and not its rom name? i'm using mamewah config if it helps.
any help would be greatly appriciated.
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
Re: mamewah game names
« Reply #1 on: June 10, 2005, 10:10:34 pm »
what emulator?
jcrouse
    • CPViewer
« Reply #2 on: June 10, 2005, 10:27:18 pm »
For consoles if you create a custom list it will truncate all the junk off the end by default.
John
dan57fina
« Reply #3 on: June 11, 2005, 12:52:34 pm »
my console list is fine...but in mame it just reads the rom name instead of the game. thanks for the replies
jcrouse
    • CPViewer
« Reply #4 on: June 11, 2005, 01:14:30 pm »
What type of list generation method are you using in your MameWAH's mame.ini file? Try one of the others like rom_folder_vs_dat_file.
John
sc1103
« Reply #5 on: June 11, 2005, 02:30:17 pm »
Alternatively, you can run a rom folder vs. -listxml for after ~.84 mame i believe, otherwise you can run a rom folder vs. -listinfo
Steve Kaz
  • Last login:May 11, 2011, 01:13:25 pm
« Reply #6 on: June 11, 2005, 03:56:47 pm »
I'm having the same thing now because the mamewah config couldn't find the dat file and i had to check "rom only" to get it to keep going forward with the emulator setup.
Where is the dat file usually kept (as i can't have it update via the internet because my cab isn't online)
jcrouse
    • CPViewer
« Reply #7 on: June 11, 2005, 04:03:18 pm »
You generate it like I said in my above post. You be better using the method in the previous post if you didn't understand my post. I'd say the best place for it is in the mame folder but YOU need to generate it!
John
spriggy
  • Last login:October 07, 2025, 01:33:26 am
« Reply #8 on: June 12, 2005, 11:21:45 am »
..for info, I'm using rom folder vs. -listxml with 0.71 without problems.
"Once a Knight, always a Knight.   Twice a night.. and your doing alright!!" ::)
sc1103
« Reply #9 on: June 12, 2005, 11:33:35 am »
Ok I'm just going by Screaming's Config, which says pre-84 use listinfo and post.84 use listxml
jcrouse
    • CPViewer
« Reply #10 on: June 12, 2005, 12:12:06 pm »
Scremaing is correct. It moved to listxml at 0.84.
John
dan57fina
« Reply #11 on: June 12, 2005, 06:35:05 pm »
thanks for all the responses. this may seem dumb but, where would i find the file for listxml?
jcrouse
    • CPViewer
« Reply #12 on: June 12, 2005, 07:01:00 pm »
"-listxml" is a command-line switch for mame. If you using version 0.84 or later you don't need a file. MameWAH will do what it need. Just set you list generation method to rom_folder_vs_listxml (I think that right).
John
spriggy
« Reply #13 on: June 12, 2005, 09:21:05 pm »
John
..in my case...that's bizzare then!? ???
« Reply #14 on: June 14, 2005, 05:55:51 pm »
Yeah very strange...it shouldn't work!  ???
spriggy
« Reply #15 on: June 14, 2005, 08:55:22 pm »
jcrouse
    • CPViewer
« Reply #16 on: June 14, 2005, 09:41:21 pm »
Just curious, R U also using a DAT file (listed in your ini). Kinda a dumb question but I have to ask.
John
spriggy
« Reply #17 on: June 15, 2005, 02:36:29 am »
John
Nope...no Mame.dat file used.   I am pointing to catver.ini...but thats about it over the default settings.
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #18 on: June 15, 2005, 08:15:39 am »
I just started trying to configure mamewah for the first time tonight, using the mameconfig app. I got it to build a gamelist, but when I added a game, it didn't update the list. I couldn't see how to make it do that. Do I have to do that outside of the config app?
« Reply #19 on: June 15, 2005, 02:39:44 pm »
What do you mean 'added a game'?  If you just added a rom into your roms folder you need to regenerate the list.
Veinman
« Reply #20 on: June 16, 2005, 08:11:16 am »
That's exactly what I want to do. My question is that I didn't see how to regen the list from the Mamewah Config app. It's fine if I need to do it manually, but if the config app will do it, then that would be great. :)
