Author Topic: mamewah setup help  (Read 1641 times)
dan57fina
  • Last login:April 23, 2006, 04:46:22 pm
  • Not bad for 14 years of age....
mamewah setup help
« on: May 30, 2005, 08:46:56 pm »
does anyone know where i can get a older version of mamewah that is compatible with mamewah steup? I am putting the finishing touches on my cabinets computer :), and any help would be greatly appriciated.
- dan
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
Re: mamewah setup help
« Reply #1 on: May 30, 2005, 09:41:48 pm »
Most of us have switched to mamewah config written by screaming- all you need is the .NET framework...ask minwah thru PM otherwise if you need an older version...he may have it
dan57fina
« Reply #2 on: May 30, 2005, 09:55:59 pm »
thanks for the reply...i'm going to give it a try now  :)
dan57fina
« Reply #3 on: May 30, 2005, 10:07:08 pm »
ok so i downloaded the .NET framework and mamewah config, but when i ran it it said "the application has generated an exeption that could not be handled" any idea what i did wrong?
spriggy
  • Last login:October 07, 2025, 01:33:26 am
« Reply #4 on: May 30, 2005, 10:18:20 pm »
Work backwards to find the error.  First try mame @ the command prompt, on the odd chance that it's @ fault(or it's settings).
Honestly, the documentation for v1.6 Mamewah is rather good and gives you ALL the info you need to setup the frontend by directly modifying your .ini files without set-up software.
"Once a Knight, always a Knight.   Twice a night.. and your doing alright!!" ::)
sc1103
« Reply #5 on: May 30, 2005, 11:34:47 pm »
Yeah the .ini files are nice, I just prefer the click and drag style of mamewah config + the autodownload of the templates from JCrouse's sites.  I find it easier for me to use it than translate what each line means in the .ini but everyone has his/her preferences correct?
