Author Topic: ps2 controller in a cab?  (Read 2853 times)
starcrudph
  • Last login:April 04, 2006, 05:43:30 am
« on: April 20, 2005, 08:28:58 am »
Has anyone put ps2 in their cabinet and connect it to joysticks? Im confused on what to do with the analog controllers, what have the others done about this,granting that there is someone whos done it already.thanks.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re: ps2 controller in a cab?
« Reply #1 on: April 20, 2005, 10:35:33 am »
Nobody plays PS2 analog games in an arcade cabinet...or at least any game that doesn't also support digital controls.  Of course you can still hook-up to the analog potentiometers and buy a pair of Happ Analog sticks with ultimate handle (http://www.happcontrols.com/joysticks/50287600.htm) for $123 each if you want  ;D.
« Last Edit: April 20, 2005, 10:38:57 am by Dave_K. »
daywane
  • GRRRR!
« Reply #2 on: April 20, 2005, 09:40:43 pm »
I have a ps2 controller in some of my cabs. game pad hacks.
analog? no.
also I have this one.
its a arcade ps1/ps2 arcade stick
now I want a ps2 to dreamcast adaptor.
then i will have a Mame PC, Ps1 and dream cast all in one cab  ;D
« Last Edit: April 20, 2005, 09:43:24 pm by daywane »
bishmasterb
  • Last login:March 23, 2014, 09:27:47 pm
  • Pressing the limits of my wife's patience...
    • Bishopzone
« Reply #3 on: April 21, 2005, 03:40:04 pm »
The Quasimoto cabinet http://www.quasimoto.com/ has analog controls that function with PS/2 and Gamecube. Does anyone know what analog sticks they are using? I'd be interested in building a Gamecube cabinet with analog controls.
I played a Quasimoto cab a year or so ago, and the controls felt pretty good. Kevin has a positive review at RetroBlast as well.
"We have just enough religion to make us hate, but not enough to make us love one another." -Jonathan Swift
starcrudph
« Reply #4 on: April 25, 2005, 09:05:53 pm »
Since alot of games use analog control, I only need help in that area. Is there a cheaper way of using analog sticks in a cab?thanks.
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
« Reply #5 on: April 26, 2005, 12:18:41 am »
I saw a pair of analog sticks that look similar to the ones that Quasimoto sells go on ebay recently.  They were still fairly expensive though.  You could always build your own analog sticks.  You could try and build some handles that could clip on to the origonal analog sticks from the Playstation controller and would basically just act as extensions.  Or I've seen people build some analog sticks out of one of these before.
Stingray
« Reply #6 on: April 26, 2005, 11:41:09 am »
The PS1 flightstick doesn't work with PS2, at least not in analog mode.
-S
Dave_K.
    • Arcade Fever
« Reply #7 on: April 26, 2005, 12:54:29 pm »
-S
Correct.  But you can still use the analog sticks to hack to a dual shock controller.
