Author Topic: I-Pac question: 28 or 56?  (Read 4038 times)
paig2956
  • Last login:February 27, 2003, 09:33:48 am
  • Cabinet newbie
« on: November 19, 2002, 09:36:57 am »
Hello all!
I am planning out my first MAME cabinet, and am already confused on one front.  Which I-Pac do I need?  I want to make a 2 player cabinet... with the following:
First player button
First player coin
Second player button
Second player coin
6 buttons for player 1
6 buttons for plater 2
2 - 8 way joysticks (how many inputs does this require?)
1 - 4 way joystick (how many inputs does this require?)
I assume that the buttons would require 16 inputs, leaving me 12 more.  How many do the joysticks take?  Are six buttons good per player?
Thanks.
Shawn
Thenasty
  • Trade Count: (+17)
  • Last login:Yesterday at 01:06:45 pm
Re:I-Pac question: 28 or 56?
« Reply #1 on: November 19, 2002, 09:50:49 am »
Why don't you count it ? Just in case you can't count, take a look at what I got for you .
First player button         1
First player coin             1
Second player button    1
Second player coin        1
6 buttons for player 1    6
6 buttons for plater 2     6
2 - 8 way joysticks      4 each = 8
1 - 4 way joystick        4
So the total is 28 and that would be IPAC2 not IPAC4
Free VGA Breakout Cable
paig2956
  • Cabinet newbie
« Reply #2 on: November 19, 2002, 09:54:11 am »
Thenasty-
I guess my confusion was that I did not know that an 8-way controller took 4 inputs.  I thought that it took 4 or 8, but I was not sure.  Thanks for your help.  I can count but I was not sure what to add.
Do four way joysticks only require 2 inputs, or do they also require 4 like 8-way?
Thanks.
Shawn
Thenasty
« Reply #3 on: November 19, 2002, 09:58:10 am »
as my reply above, 4-way or 8-way still takes 4 inputs.
The 8-way (up.down.right,left) then where the hell to make it 8 ? well when you push the joystick diagonally, UPandRIGHT this trigger the diagonal that make it move diagonally. so, you have 4 diagonals and the other 4.
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #4 on: November 19, 2002, 10:13:13 am »
You could also save yourself 4 inputs and wire the 4 way into the same inputs as the player one 8 way. That would free up a few buttons in case you wanted a dedicated escape or something... You just have to remember you cant bump the 8 way while you're playing 4 way games (or vice versa)  ::)
If you build a frankenpanel, chances are I don't care for you as a person.
Scotty
  • Last login:May 01, 2025, 09:16:56 am
« Reply #5 on: November 19, 2002, 12:30:33 pm »
Brax,
I was just about to say the same thing.  I have a HotRod SE and have hacked all kinds of contraptions to it.  I currently have a Midway coinbox wired to the 3 and 4 keys inside of the HotRod, and I aqquired a 4 way Pac-Man joystick that I wired to the left control pannel.  Works great in 4 way games, but have not mounted it yet.  I still have to hold it in my hand like the Atari 2600 days.    ;D
Works great though.  I am in the process of building a Mame cab out of a PLaychoice 10 machine, with dual monitors.  Until then, I have a "Poor Mans Mame Cab" with a HotRod SE, a KDS 19" monitor that is vertical more than horizantal, a coin box screwed in to the fron side of my bookcase connected to the HOtRod, and the 4 Way PacMan stick for the older games.
Scotty
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #6 on: November 19, 2002, 12:50:14 pm »
What brax said, wire the 4way to the same input at the player 1 8way, it's the same inputs anyway.  that will leave you with extra buttons if you want a dedicated button for pause, quit, or whatever.  Check out my cabinet, all that is wired to the IPAC2 (there was no IPAC4 when I got mine).
The buttons on the shefl, the left group of 4 are start and coin buttons.  The middle three, quit, power, pause.
The spinner and trackball are USB...
To word it another way than TheNasty, a 4way joystick bocks the joystick from moving tot he diagnals.  And 8way doesn't, hence eight directions then.  But it still just has 4 buttons, it know the diagonal when the up and left button are pushed, etc...
