Author Topic: Missle Command - Scrolls - Too Big For Monitor  (Read 1589 times)
DreamWeb
  • Last login:July 25, 2020, 08:36:59 pm
« on: April 08, 2005, 12:57:18 am »
Hey guys.. I'm running MAme on my television.  Most games look fine.. but, Missle Command has an issue.
The game screen doesn't fit on my TV screen..  I am using the trackball to play the game.. but the trackball also scrolls the screen while I play.    It's about 20% bigger than the actual TV screen.
Very odd.
I'm running windows and mamewah at 800x600
Most games don't have this problem.
Can anyone offer up a suggestion?  thanks guys!
d.
« Last Edit: April 08, 2005, 01:01:21 am by DreamWeb »
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
Re: Missle Command - Scrolls - Too Big For Monitor
« Reply #1 on: April 08, 2005, 06:42:29 am »
A TV can't display 800x600 so the video driver creates a panned display.
Use a resolution with 480 (NTSC) or 576 (PAL) lines.
Lilwolf
  • Last login:Yesterday at 07:14:03 pm
« Reply #2 on: April 08, 2005, 09:14:42 am »
try forcing a resolution and turning hwstretching on and see if it fixes it.  You will get a speed hit, but will tell you if the video card is stretching wrong... or the resolution mame is the problem.
DreamWeb
« Reply #3 on: April 08, 2005, 10:47:01 am »
Thanks guys.  I'll give that a go tonight!
WOOO!  I've got an arcade in my living room!!!!!  (I just finished building it...)  So excited.
Anyhow.  Thanks!
d.
surf
  • Last login:December 15, 2011, 11:43:38 am
  • I've built my own arcade!
« Reply #4 on: April 08, 2005, 01:55:31 pm »
Set MAME to run at 800x600 in the ini file.  This will force all games to fit.
Surf
Surf
http://www.freewebs.com/homepubarcade
(Just a homemade arcade)
DreamWeb
« Reply #5 on: April 08, 2005, 04:44:42 pm »
Will this force games that use to run at 320x (whatever) to run at 800x600?  Is this the most ideal way to run this?  I'm thinking I'd be taking quite a speed hit.
d.
