Author Topic: Cannot create game list using Screaming's MAMEWAH config  (Read 1633 times)
SmokinGun
  • Last login:December 27, 2020, 01:53:10 am
« on: March 31, 2005, 01:55:04 pm »
Hello,
I'm trying to use Screaming's MAMEWAH config to configure MAMEWAH on my arcade cab. It looks like a neat program but I cannot get it to create a game list correctly. FYI, the program can be found here.
http://mamewah.mameworld.net/links.htm
I have the newest version of MAMEWAH, MAME, Arcade VGA, CLRmame, etc.
I get to the section where it generates the program list and it defaults on the method of creating a gamelist using a .dat file and some other kind of file (I'm at work now so I can't remember the details.) When I try and do this it gives me an error saying 0 games found. There is another option to create the game list using only the other kind of file. When I do this, it created the list but the names are all done by filename and not the game name. For example, Street Fighter Alpha 3 will appear as SFA3 in Mamewah. Also, the artwork is not appearing in MAMEWAH even though I told Screaming's MAMEWAH config where to find it in my C:\mame folder.
I know that CLRmame creates .dat files, so I installed CLRmame and created a .dat file using MAME. It generated a .dat file and says I have sets missing because my mame set isn't up to date (it's only at .89 but that shouldn't matter, right?). I point the Screaming MAMEWAH config to my newely created .dat file and it still doesn't work, same error.
My question is, how do I get a mame.dat file and how do I get it to generate the list correctly in MAMEWAH using Screaming's MAMEWAH config?
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
Re: Cannot create game list using Screaming's MAMEWAH config
« Reply #1 on: March 31, 2005, 02:23:23 pm »
First try running a Rom Folder vs. -listxml to get your list. If not, I had a similar problem I believe screaming updated his program to fix this issue it had to do with the display of capital letters, look at this thread for a link to his "fixed" version...it might work if not ask screaming.
http://forum.arcadecontrols.com/index.php/topic,34284.0.html
SmokinGun
« Reply #2 on: April 01, 2005, 09:05:22 am »
I got it to work.  Screaming told me to do the same thing on another forum, thanks.
