Author Topic: Dreamcast Arcade Monitor support.  (Read 2920 times)
metro
  • Last login:November 27, 2005, 12:04:03 am
« on: March 21, 2005, 10:47:03 pm »
Ok I need some help guys.
I do not have a vga cable so I have to make one from scratch.
 I have a DC VGA box with the correct wire cut. I need some help making a cable to connect from my monitor to the vga box. On my monitor it has r/g/b/h/ground wires and I know to twist the horizontal and vertical wires from the box to the monitor and the r/g/b/ is a srtaight connection. Now with this cable where would I connect the ground coming from the monitor. Wich pin on the vga 15-pin would I connect it to. Do I need to connect it to one pin or should it be connected to several pins like the r/g/b grounds along with the h/v grounds.
metro
Re: Dreamcast Arcade Monitor support.
« Reply #1 on: March 22, 2005, 02:22:43 am »
Got it. I hooked up monitor ground to pin 10 and walah, I'm a happy man. I have two discolorations in the top right and bottom left corner but I can live with it for now. Next on the list is to connect controls. Thanks for all the info on this site and everyone that helped out.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #2 on: March 22, 2005, 04:35:19 am »
The coloring problems in the corners sound like your monitor needs to be degaussed.  Either that or you have speakers to close to the monitor.
metro
« Reply #3 on: March 23, 2005, 10:19:52 am »
My cab has a button that takes care of that problem. i thought it was my other cab that only had that feature. I have an astro city and a new astro city.......
They both also have a volume control so would it have an amp itself or would normally is the sound powered from the game board. I am looking for a solution use the existing speakers with the cab and DC.
« Last Edit: March 23, 2005, 10:21:57 am by metro »
Dave_K.
    • Arcade Fever
« Reply #4 on: March 23, 2005, 04:27:23 pm »
Trace the L+R sound input from the jamma connector to the sound board, and run a wire from your hacked VGA box to that for sound.  Other than that, you could also buy a SA-155 amp (see ebay) they are small and powerful, and will drive your original 8ohm speakers.
metro
« Reply #5 on: March 23, 2005, 05:32:17 pm »
I thought jamma was mono and not stereo. I was hoping i could find a stereo input in this cab. My new astro city has stereo input. the regular astro to my knowledge only accepts mono.
Dave_K.
    • Arcade Fever
« Reply #6 on: March 23, 2005, 05:42:43 pm »
Well does the older astro have 2 speakers or one?  Yes the std jamma spec calls for mono, but later cabs utilize 2 more jamma pins for stereo.  I believe its pins L,10,M,11.  If the older astro has a mono amp in it then you are pretty much screwed and would have to buy an SA-155 like I said previously.
metro
« Reply #7 on: March 23, 2005, 07:39:19 pm »
I'll look into the other pins. My cab has 2 speakers in it. But more than likely I will have to buy an amp wich is not a prob really, just trying to utilize what I have already.
Dave. Do you know about Naomi hardware.......
Dave_K.
    • Arcade Fever
« Reply #8 on: March 24, 2005, 11:03:58 am »
Gozur (who is also on the board here) recently bought one.
metro
« Reply #9 on: March 25, 2005, 04:56:58 pm »
Well I figured out what I was wanting to know for now but thanks Dave you have been a big help and inspiration. You always have a god attitude and are not negative when people need help. :)
Dave_K.
    • Arcade Fever
« Reply #10 on: March 25, 2005, 05:28:45 pm »
Yeah, I got to do something about that god complex... ;D  joking...
Anyway, thanks.  I recently aquired an Astro City 2 cab that I'm going to overhaul and make into a rad looking dreamcast arcade cabinet...so stay tuned!
« Last Edit: March 25, 2005, 07:06:02 pm by Dave_K. »
metro
« Reply #11 on: March 25, 2005, 10:28:37 pm »
Can't wait so keep us posted man. I'll be looking forward to it. :angel:
Dave_K.
    • Arcade Fever
« Reply #12 on: March 26, 2005, 11:25:33 pm »
I started posting pics in the projects forum here:
http://forum.arcadecontrols.com/index.php/topic,34226.0.html
