Author Topic: Monitor brightness flickers  (Read 1563 times)
Captain_Dingo
  • Last login:November 28, 2018, 05:57:32 pm
« on: March 01, 2005, 08:51:37 pm »
I have a 25" Hantarex Polo (I believe) monitor in a Midway Universal cabinet (JAMMA with Ultimate MK3 in it).  When I first turn it on, the brightness is quite low and it must be adjusted to be playable.  After a while, it will flicker, and then it will hold brightness for a few minutes, then flicker and lose it, etc.
Does this sound like something that might be repairable?  The monitor has a little noticeable burn-in (it was obviously in a Street Fighter at some point in its life), so I'm thinking that if it's going to be something too expensive to fix, I might just spring for a new monitor.
Opinions?
Witchboard
Re: Monitor brightness flickers
« Reply #1 on: March 01, 2005, 10:46:24 pm »
Flyback going bad?  ???
Ken Layton
  • Guru
  • Technician
« Reply #2 on: March 01, 2005, 11:38:17 pm »
While I've never repaired nor seen a Polo, Hantarex are well known eaters of capacitors and flybacks.
Captain_Dingo
« Reply #3 on: March 02, 2005, 10:42:59 am »
Rumor has it this monitor was capped not too long before I got it.  I spoke to one person locally, and he seemed to think it was possibly the flyback as well.
Should I just replace the whole thing?
Ken Layton
  • Guru
  • Technician
« Reply #4 on: March 02, 2005, 11:12:10 am »
The flyback is on sale at www.penn-ray.com for $16.95 versus you buying a whole new monitor for $400.
