Author Topic: NEVERMIND - Need help getting arcade VGA card to work with 25" monitor  (Read 1968 times)
Wyluli
  • Last login:February 11, 2013, 06:38:03 pm
  • Stupid Stupid Rat Creatures!
Well, I have my pc all loaded up with games and ready to go.
« Last Edit: February 17, 2005, 02:42:47 pm by Wyluli »
Fat_Trucker
  • Last login:September 08, 2010, 11:44:22 am
Re: NEVERMIND - Need help getting arcade VGA card to work with 25" monitor
« Reply #1 on: February 20, 2005, 04:02:04 pm »
Might be a bit late and you have it sorted by now but if not.
I know its an obvious one but have you loaded the AVGA drivers?.
My first thought when I read your post was that I would definitely check your AGP slot on your mobo.
It may be that this is a very old mobo and there is not enough voltage going through your AGP slot to power the card if it is a very early AGP board. Check your Bios and see what voltage is being pushed through AGP.
Another consideration is to check the card is seated properly and there is always the possibility that you have got yourself a faulty card.
I didn't touch it....honest!
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #2 on: February 20, 2005, 06:12:58 pm »
Lesson on agp slots.
The AGP 1.0 specification defined 1x and 2x speeds with the 3.3v keyed connector.
The AGP 2.0 specification defined 1x, 2x and 4x speeds with the 3.3v, or 1.5v keyed connector or a 'Universal' connector which supported both card types.
The AGP Pro specification defined 1x, 2x and 4x speeds with the 3.3v, or 1.5v keyed connector or a 'Universal' connector which supported both card types.
The AGP 3.0 specification defined 1x, 2x, 4x and 8x speeds with the 1.5v keyed connector or a 1.5v AGP Pro connector.
Each up-grade is a supper-set of the 1x mode, so 4x will also support 1x. The base clock rate is 66MHz, but to achieve to 2x, 4x, and 8x speeds the clock is doubled each time. AGP uses both edges of the clock to transfer data.
AGP (1x): 66MHz clock, 8 bytes/clock, Bandwidth: 266MB/s [3.3V or 1.5V signal swing]
AGP 2x: 133MHz clock, 8 bytes/clock, Bandwidth: 533MB/s [3.3V or 1.5V signal swing]
AGP 4x: 266MHz clock, 16 bytes/clock, Bandwidth: 1066MB/s [1.5V signal swing]
AGP 8x: 533MHz clock, 32 bytes/clock, Bandwidth: 2.1GB/s [0.8V signal swing]
Now alot of older chipset motherboards only support up to agp 2x.
Some actually say 4X
No problem right???
WRONG.
I've ran into quite a few 4x motherboards that don't properly support the 1.5v siginaling. They just default to 3.3 v.
Here's a ati chart of the different agp specs for ati cards.
http://www.ati.com/support/faq/agpchart.html
Now notice that even though the chipset might support 3.3v mode that the cards themselves don't have to implement that feature.
Newer video cards only backstep to 4X, and most  of the newer cards that are 1.5volt or .8v only. The rash of problems that people are having with avga 9200 cards seem to be when they are trying to use them with older boards.
Either upgrade motherboards or find a older series 7000 based avga card.
Later,
dabone
ssjenkins
  • Last login:May 06, 2008, 01:08:32 pm
« Reply #3 on: February 21, 2005, 03:56:04 am »
I (and a few others) have had the exact same problem . In the end I had to buy a new motherboard as it just wouldn't work in my Dell Dimension 8100 or IBM Netvista . Sorry to be the bearer of bad news but it sounds as if you'll need to do the same .
Sammy
Born to lose .....
Wyluli
« Reply #4 on: February 21, 2005, 04:20:02 pm »
Sammy
Thanks.  It totally sucked realzing that the card would not work in my old pc after all the trouble I went through getting it up and running again.  *sigh* Doesn't surprise me though, story of my life haha.  I'm thinking about buying this config:
AMD SETUP:
PROCESSOR: $69
AMD Sempron 2400+ 1.667GHz, Socket A Processor - Retail
- Specifications -
Manufacturer: AMD
Model: SDA2400BOX
Core: Thorton
Operating Frequency:1.667GHz
FSB: 333MHz
Cache: 256K (exclusive) L2 cache; 128KB L1 cache
Voltage: 1.65
Process:0.13Micron
Socket: Socket A
Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
Packaging: Retail (Box with Heatsink and fan)
Item#: N82E16819104210
ASUS "A7N8X-E Deluxe" nForce2 Ultra 400 Chipset Motherboard for AMD Socket A CPU -RETAIL
PRICE: $90
Model# A7N8X-E Deluxe
Item # N82E16813131478
Specifications:
Chipset: NVIDIA nForce2 Ultra 400 + MCP-T
FSB: 400/333/266/200MHz
RAM: 3x DIMM for Dual-Channel DDR400/333/266 Max 3GB
IDE: 2x ATA 133 up to 4 Devices
Slots: 1x AGP Pro/8X, 5x PCI, 1x Wi-Fi
Ports: 2xPS2,1xLPT,1xCOM,2xLAN,6xUSB2.0(Rear 4),SPDIF Out,Audio Ports
Onboard Audio: Realtek ALC650 6-Channel Codec
Onboard LAN: Realtek 8201BL 10/100Mbps + Marvell 88E8001 GbE
Onboard SATA/RAID: 2x Serial ATA by Silicon Image Sil3112A, RAID 0/1
Form Factor: ATX
Kingston ValueRAM 184 Pin 256MB DDR PC-2100 - OEM
PRICE: $35.67
- Specifications -
Manufacturer: Kingston
Speed: DDR266(PC2100)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5
Support Voltage: 2.5V
Bandwidth: 2.1GB/s
Organization: 32M x 64 -Bit
Warranty: Lifetime
Model#: KVR266X64C25/256
Item#: N82E16820141002
