Author Topic: Eygo 19"  (Read 3948 times)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Eygo 19"
« on: October 20, 2002, 05:58:01 am »
Ok, anyone know the specs of the 19" Eygo VGA?
I was wondering if I could somehow hook up my ddragon2 pcb to it.
Is there a 19"-25" arcade monitor (pref 19") that is like the following wells gargner 27" with rgb AND vga inputs.
http://www.wellsgardner.com/wellsgardner31/supportdata/27%20inch%20D9200%20Spec%20Sheets.pdf
With that monitor could one have both PCBs and a computer hooked up to it?
« Last Edit: October 20, 2002, 06:16:05 am by SirPoonga »
Rod1968
  • Last login:February 03, 2007, 10:19:45 pm
Re:Eygo 19"
« Reply #1 on: October 20, 2002, 10:37:30 am »
I have a 19" eygo and it only has the vga connector on it, there is no header or molex connector for an RGB connection. Here a the specs
http://webpages.charter.net/redpinata/redpinata/downloads/eygospecs.txt.
The monitor you linked to looks like it can have a board and a video card hooked to it simultaneously since it supports cga/ega and vga connections but I can't be certain on it though, your best bet would be to contact WG directly on the subject, I have called them on several occasions and they've been more than helpfull
Rodney
SNAAAKE
  • -Banned-
Re:Eygo 19"
« Reply #2 on: October 20, 2002, 02:22:12 pm »
Well,
Its says  CGA/EGA/VGA right on the retail box of the monitor as I had 3 of these.
NOW,you can either cut the vga cable then look for the red,green,blue,ground,sync wires then hook it up directly.It wont hurt the monitor as you are goin down with the scan rate here.Then use a swith box to swith between your jamma boards and PC.
I never tried so no gurentee here :P but you could always give it a try. :)
SirPoonga
  • Puck'em Up
Re:Eygo 19"
« Reply #3 on: October 20, 2002, 04:11:39 pm »
So, is there a way to hookup my double dragon pcb to that eygo monitor?
Rod1968
Re:Eygo 19"
« Reply #4 on: October 20, 2002, 09:43:51 pm »
Well,
I have one of these monitors in a retail box sitting on the floor right next to me as I type this reply an no where on it does it say CGA/EGA/VGA ,it has a box on it that says vga/std or dx and cga/std or slt that the manufacture checks depending on what type of monitor gets puts in the box before it goes to the distributor. These monitors are nothing but regular open frame VGA computer monitors with a max resolution of 640 x 480 so I don't think he can do this it without ruinning the monitor or the board or maybe both.
If this were true in theory you could do this with all monitors that support higher resolution an scan rate with out special software or hardware but thats just not the case.
horizontal scan frequency range
Wells gardner d9200 series monitors
15.75 to 31.5 KHz
Should work but I would call WellGardner to make sure
Eygo 19" vga model # amn19v-rb
30.5 to 32.5KHz
Will not work
IMHO
Rodney
« Last Edit: October 20, 2002, 09:55:46 pm by Rod1968 »
SNAAAKE
  • -Banned-
Re:Eygo 19"
« Reply #5 on: October 20, 2002, 11:43:30 pm »
I dont have the boxes anymore..i thought it said like that(cga,vga)....
Sorry for the misunderstanding :P
