Author Topic: Advancemame Compiling Problem please help  (Read 926 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: January 28, 2005, 12:38:02 am »
ok i have got the diff files for advancemame and the mame source...i wanted to add the no nag patch which i did but i cannot get this frickin compiler to work....can anybody do this as im kinda lost with this linux stuff im just learning it :)
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
Re: Advancemame Compiling Problem please help
« Reply #1 on: January 28, 2005, 02:47:00 am »
Fill out the following and return to your friendly neighbourhood geek:
1) Distribution used?
2) Kernel used?
3) Graphics Library used (SVGALib/FrameBuffer/SDL)?
4) Version of AdvanceMame being compiled?
5) Version of diff files being used?
6) Exact error message at time of compile error (might need to scroll up a few lines from the last error code to find it)?
7) Does it compile cleanly without the diff files being patched in?
GMZombie
« Reply #2 on: January 30, 2005, 06:45:59 pm »
umm let me see
i used advancemame .90 diff files....
mame .90 source files
im on windows xp and am using msys which is a windows/dos based compiling shell...with gcc 3.2.2
umm svgalib i believe
i get this error
obj/mame/windows/blend/advance/dos/file.o
gcc.exe: no input files
make: *** [obj/mame/windows/blend/advance/dos/file.o] Error 1
no it dosent compile correctly...here is the error i get with a normal source from mame.net
Compiling src/version.c...
make: *** [obj/mame/version.o] Error 1
again im not a compiler so i dont know what im doing wrong so please help if you can thanx :)
GMZombie
« Reply #3 on: January 31, 2005, 04:27:15 am »
i dunno im no linux user by any means yet so if there is anybody that would compile this for me i would greatly appriciate it....
