Author Topic: XP Shell and Project64 Help!  (Read 1426 times)
Scanner
  • Last login:April 10, 2006, 07:57:44 pm
  • You Know!
« on: January 25, 2005, 07:03:07 pm »
I have project64 up and running on my cab fine .  However, I am having problems when trying to run it from a windows XP shell.  I have mamewah setup and running in a shell so that no other programs load.  It works great for MAME, ZSNES, VirtuaNES and so on but when I try to run Project64 it won
Silver
  • Last login:April 16, 2025, 04:09:53 pm
  • Cunning like the Fox.
    • Mods'n'Mods
Re: XP Shell and Project64 Help!
« Reply #1 on: January 26, 2005, 09:34:40 am »
Sounds like a focus issue - not sure why booting direct to MameWah as your shell makes a difference. Try the different launch commands in Mamewah (see the docs) and see if changing the p64 launch method helps....
Scanner
  • You Know!
« Reply #2 on: January 26, 2005, 08:34:13 pm »
I got it!  ::)Geez this is a no brainer.  Project 64 has user set settings for each login.  So while I set everything up as administrator my arcade login in was not changed.  I disabled the shell and altered the settings from my arcade login and it works.
Scanner
