Author Topic: vplaunch freezes my computer when i try to exit?(solved)  (Read 1058 times)
tyweed
  • Last login:March 09, 2008, 01:29:03 pm
« on: January 20, 2005, 06:38:59 pm »
I have the latest version of both vpinmame and cvplaunch. Everything loads just fine. However when i hit escape everything freezes. It will show parts of the visual pinball application and the table itself and then locks up. Anyone else have this problem? Just wanted to see if there was a special trick to get it right.
Solution================================
For whatever reason turning visual pinball into windows 95 compatibility did the trick!
« Last Edit: January 21, 2005, 03:07:47 pm by tyweed »
coachcarstens
  • Last login:November 19, 2007, 10:42:59 pm
Re: vplaunch freezes my computer when i try to exit?
« Reply #1 on: January 20, 2005, 10:33:07 pm »
I think there is an update to visual pinball.  I believe that is how I fixed this problem when I had it.  I think the problem was introduced with xp sp2, but not toally sure on that.
Chris
tyweed
« Reply #2 on: January 20, 2005, 10:36:38 pm »
i'll try it thanks!
