Author Topic: Capacitor question  (Read 1336 times)
GuinnessGuy74
  • Last login:November 08, 2011, 11:01:43 am
Capacitor question
« on: January 20, 2005, 04:09:22 pm »
I am trying to identify this capacitor:
MYR .022 10% 50v
What type is it? I have never seen MYR before, I am assuming the R stands for radial?
Thanks,
Jim
« Last Edit: January 20, 2005, 04:15:26 pm by GuinnessGuy74 »
Ken Layton
  • Guru
  • Technician
Re: Capacitor question
« Reply #1 on: January 20, 2005, 06:12:45 pm »
MYR is an abbreviation for mylar (a.k.a. polyester or metal film). Radio Shack # 272-1066 will work.
« Last Edit: January 20, 2005, 06:35:56 pm by Ken Layton »
GuinnessGuy74
« Reply #2 on: January 20, 2005, 07:45:06 pm »
Thanks Ken, I figured it was a mylar, but wanted to be sure! I didn't want to "assume" and then blow the monitor up. I wound up not needing it anyway, since it was soldered directly between pins on the IC. I didn't see it on the component side and thought it might have broken off because I saw some solder coming through the hole!
Thanks, Jim
