Author Topic: Dreamcast - Gaunlet Legends - Hacked controllers - Does it play OK with d-pad?  (Read 2027 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
Ummm, you might be able to guess from the topic what I'm going to ask, but the topic only lets you use so many characters... :)
I'm getting two Dreamcast controllers hacked up so I can attach them directly to my arcade control panel.  The controllers are being hacked to use the d-pad (not the analog stick, even though it's possible it's pointless if I understand it correctly).
So, I'm wondering if I could still play one of my favorite games: Gauntlet Legends.
I've tried playing it using just the d-pad on the Dreamcast (w/o arcade controls hooked up) and it controls a little strange, it seems like you might need to use the analog stick.  However, I -REALLY- want Gauntlet Legends on my arcade cabinet and I don't think there's any other way to do it...
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
well, unless youre going to use 49way joysticks youre not gonna get the feeling any different then using the D pad. which btw i think no one has hacked a 49way to a controller yet btw.
think about it, your joystick is only 8 way, so is your Dpad, its gonna be the same way. I own a real Dark Legacy machine and it has 8 way joysticks and works fine. it was a conversion and im guessing the person who did it didnt feel like buying 49ways like they were supposed to. the controls are fine IMO, you may have trouble aiming a super move in a very specific direction on occassion but most of the time the game helps auto aim anyway so it doesnt matter
"Owens is the ringleader in the ass hat circus"  D K
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
49 ways will not be an easy hack.
Dreamcasts use halls effect joysticks.  These are very similar to pots (changes resistance) but it changes them in 4 directions instead of pots which only do it in 2 (center in a pot joystick is usually 1/2 the resistance possible where will be bax in a halls effect.
You CAN hack the halls effect joysticks into a normal joystick but it will be full up/down/left ect on the connection.
A 49 could be done with ever connection, removing a resistor from a curcuit.  But expect a little board for each direction...
