Author Topic: Idea: DOS Sound drivers from Linux Source  (Read 2631 times)
SirPeale
  • Green Mountain Man
« on: January 02, 2005, 08:34:38 pm »
Currently there are *very* few DOS drivers being released for current soundchips.  This makes things kind of difficult for all-in-one motherboards to be used without having a soundcard hanging off the side.
How hard would it be to use the Linux drivers to make DOS drivers?  There's a lot of support there, as there are a *ton* of working drivers.
Buddabing
Re: Idea: DOS Sound drivers from Linux Source
« Reply #1 on: January 02, 2005, 10:26:54 pm »
Please read the wiki!
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
« Reply #2 on: January 02, 2005, 10:56:32 pm »
The drivers you speak of are not standalone software.   They are integrated into packages like ALSA:
http://www.alsa-project.org/
Which in turn use hooks directly into the linux kernel.   I'm no driver programmer, but I don't think porting this across to DOS would be a trivial task.
Instead, I think you'd be better off trying to convince front end authors to consider porting their work to linux with SVGALib and FBDev support for X-less graphics in linux, or alternatively open-sourcing their work so that others can contribute non-DOS/Windows ports.
I know I'd LOVE to see a MAMEWah clone hit Linux.  Currently there's MAMEd which is SDL only:
http://www.xs4all.nl/~phulshof/pictures/mamed.jpg
Which is the prettiest of linux front-ends, but still no support for X-less setups ala AdvanceMenu (which isn't quite as pretty).
GadgetGeek
  • Last login:July 09, 2024, 09:32:57 am
  • whatever
« Reply #3 on: January 03, 2005, 07:26:16 am »
maybe this book might help?
http://www.amazon.com/exec/obidos/tg/detail/-/0201608375/002-5633404-3845637?v=glance
I wish I had more time to contribute to this.
SirPeale
« Reply #4 on: January 03, 2005, 07:50:04 am »
I speak of the kernel drivers themselves, but likely those drivers have their hooks deeply embedded into the Linux kernel.  How hard it would be to separate those into standalone units, I can't say.
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
« Reply #5 on: January 03, 2005, 08:22:43 am »
vsyncmame converted some ALSA sound drivers to DOS. That could be a start if someone want to convert more of them.
Advancemame uses the existing vsyncmame drivers so some ac97 chips are already supported. Try with "device_sound vsync/ac97"
SirPeale
« Reply #6 on: January 03, 2005, 08:27:53 am »
Reeeeeeeeeeeeeeeally...guess I'll do some looking @ AdvanceMame.  I've looked before, but have never been able to get it to do what I want.
*shrug* I'll look again!
SirPeale
« Reply #7 on: January 03, 2005, 12:00:51 pm »
Burning an AdvanceCD now...we'll see how it goes!
SirPeale
« Reply #8 on: January 03, 2005, 02:29:30 pm »
Well, AdvanceCD discovered all my hardware, and made a nice little playable thing.
I couldn't get Killer Instinct 1 or 2 to play, but I suspect that's because I may be using incompatible versions of Mame/ROMs.
AdvanceMenu is interesting, to say the least.  It doesn't seem exactly cab friendly.
But this was all running under Linux.  I haven't tried AdvanceMame on here yet.  The last few times I played with it I got nothing but garbled graphics onscreen.  And I played with it on a couple different systems, and on an arcade monitor.
whammoed
  • Last login:May 07, 2026, 10:56:39 am
  • Crack don't smoke itself
    • NiceMite
« Reply #9 on: January 03, 2005, 03:31:16 pm »
SirPeale
« Reply #10 on: January 03, 2005, 05:42:50 pm »
Oh, it *looks* pretty enough.  It's how you select a game that wasn't so cool.  Although I'm sure if it wasn't on a CD you could change the defaults.
maraxle
« Reply #11 on: January 03, 2005, 06:07:35 pm »
I use AdvanceMenu, and all I have to do is scroll to the one I want and hit the 1p start button.
