Author Topic: 25" Wells Gardner repair help  (Read 1848 times)
Prodmage
  • Newbie
  • Last login:December 29, 2004, 02:40:20 am
« on: December 29, 2004, 02:39:15 am »
Hey, I've got a 25" wells gardner monitor from an old TMNT machine that I have been working on.  Not too long ago a poorly attached speaker inside the arcade fell off and disconnected/broke the neck board at the pin connector.  I tried just plugging it back in (though i may have done it incorrectly) but i don't get any picture on the screen.  Any help would be appreciated.  Thanks.
Ken Layton
  • Guru
  • Technician
Re: 25" Wells Gardner repair help
« Reply #1 on: December 29, 2004, 10:37:24 am »
Ummm...... if you haven't repaired the broken neck board then you won't get a picture!
Are you sure only the neckboard was damaged and not the neck of the picture tube itself?
You can call the parts department at Wells-Gardner and order a new neckboard.
« Reply #2 on: December 29, 2004, 10:53:01 am »
While we're on the topic... I have a Hantarex that I got to mess around with, unknown working order, that has a snapped neckboard.  I haven't really looked at the PCB yet... how hard are these to jump so it works again, usually?  I'm still fairly new but am learning at a lightning pace...
Ken Layton
  • Guru
  • Technician
« Reply #3 on: December 29, 2004, 10:59:45 am »
Most neckboards (depending on the severity of the damage) are fairly easy to repair provided it's clean and you do a good job of glueing the broken section thus strengthening it.
« Reply #4 on: December 29, 2004, 11:07:45 am »
I'll take a look at this one and see... I was actually thinking of using some small plastic or wood strips around the edges to hold the halves in place, rather than just gluing the crack.  Or is that silly?
Ken Layton
  • Guru
  • Technician
« Reply #5 on: December 29, 2004, 11:12:05 am »
I use epoxy glue to fill in the crack and hold the broken parts together.
« Reply #6 on: December 29, 2004, 11:31:43 am »
I'll go with that then... you're the man with about, oh, 100% more experience than I have.   ;)
