Author Topic: Copying PC Applications from old computer to new one?  (Read 3142 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: December 14, 2004, 05:03:16 pm »
I'm trying to put some of my pc applications (games and such) from my old computer onto my new computer.  I have found out that while it will work for alot of programs there a quite a few that will not work.  It's not a huge deal as I can install the programs from the installation disks but it sure does save alot of time just to copy the folders over a lan.
Couple of questions:  What prevents the programs from working if you just copy the folders? I assume it has to do with registry settings.
The other question: Is there a way around this?
I am using w2k on both computers.
Thanks.
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
Re: Copying PC Applications from old computer to new one?
« Reply #1 on: December 14, 2004, 05:06:25 pm »
The registry entries, you are correct.
To my knowledge, there is no way around installing them again.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #2 on: December 14, 2004, 06:14:42 pm »
Drive Image will work
Ghost should work
Any drive imaging program should work.
zaphod
    • ArcadeCab.com
« Reply #3 on: December 14, 2004, 07:37:11 pm »
Ghost should work
Drew,
Will those work for situations other than replicating an entire drive?  I assumed he only wanted a subset of the existing apps.  I thought those were all or nothing.
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #4 on: December 14, 2004, 07:39:33 pm »
backing up the Registry entries is the work around..
its not hard..
DrewKaree
  • HAH! Nice one!
« Reply #5 on: December 14, 2004, 07:41:58 pm »
Yah, after re-reading his post, I think you're right.
In any case, yes, drive imaging is an all or nothing - OS and all - solution
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #6 on: December 14, 2004, 09:43:20 pm »
Aloha Bob...
I've used it for alot of business apps.
here's a review.
http://www.pcmag.com/article2/0,1759,1593237,00.asp
Later,
dabone
Chris
    • Chris's MAME Cabinet
« Reply #7 on: December 14, 2004, 10:28:24 pm »
Move Me from Spearit should work... http://www.spearit.com/
Move Me was written by Dan Spear, who was one of the top brains when I was with Quarterdeck.
--Chris
--Chris
Popcorrin
« Reply #8 on: December 15, 2004, 09:13:53 am »
Wow, thanks for all the responses. :)
I'll check out a couple of those programs and see how it works out!
str1der
  • Last login:March 04, 2021, 04:35:31 pm
  • Live it!
« Reply #9 on: December 15, 2004, 04:02:15 pm »
I'll second AlohaBOB's PC Relocator Ultra Control.
I just used it to migrate almost everything from one system to another with great success. It moves email, favorites, folders, apps (Office, Adobe......). It will even relocate to a different drive. Like if it was originally installed on D: but needs to move to c: on the new system. It will do this while taking care of the registry entries.
Mameotron
« Reply #10 on: December 16, 2004, 05:48:52 pm »
This thread just got me thinking....
I had a hard drive crap out on me, as it turns out there are bad sectors on my windows partition.
terryd
  • Last login:October 27, 2005, 03:14:58 pm
  • To each his own... Unless I want it first!
« Reply #11 on: December 17, 2004, 11:57:17 am »
Start Regedt32, navigate to the HKEY_LOCAL_MACHINE hive, and then click to select the root object. (Highest level in the tree)
Click to select the
Mameotron
« Reply #12 on: December 17, 2004, 06:46:30 pm »
Thanks for the help, Terryd!!
