Author Topic: Need help identifying a set of wires  (Read 1085 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: November 25, 2004, 12:15:26 am »
I recently decased a pc monitor and I noticed a flat band of wires surrounding the monitor.  It almost looked like a miniature ide cable and both ends of this cable hooked to a pcb board.  It's on a 21" mitsubushi svga monitor.   I have decased pc monitors in the past and have never seen a wire like this.  Usually the only wire surrounding the monitor is the degaussing cable.
I guess the main thing I would like to know is what this cable does and if I can remove it.
Ken Layton
  • Guru
  • Technician
Re: Need help identifying a set of wires
« Reply #1 on: November 25, 2004, 01:54:03 am »
If it's connected to something I certainly would NOT remove it.
Popcorrin
« Reply #2 on: November 25, 2004, 10:34:17 am »
The problem is with the monitor decased there is nothing to hold it in place as it was glued to the front plastic piece.  I guess I could hot glue it to the tube if it's not a good idea to remove it.
SirPeale
  • Green Mountain Man
« Reply #3 on: November 25, 2004, 11:10:55 am »
Sounds like the monitor adjustment board.  Like Ken said, I wouldn't remove it!
