Author Topic: phew! successfully modchipped my xbox!  (Read 1506 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: November 20, 2004, 09:11:17 pm »
i am now very pleased - seems that i sucessfully installed my xecuter 3 modchip
took about 2 hours and the soldering was a bit nerve
racking. my hand was not steady and my soldering iron
bit was too large for the job so had to take it very slow.
hardest part was what is called the LPC rebuild where
you have to rewire various points on the motherboard
(VERY small solder points) to the connector that you
have to install which the xecuter pcb plugs into.
luckilly i bought one of these to help...
http://www.baldbouncer.co.uk/catalog/product_info.php/products_id/90?osCsid=a85c89c16dd44ea2b34f1f81577d5ce0
unfortunately it didnt line up quite right with the solder points on the motherboard (probably my fault!) - so ended up spending ages making the connections right.
i think LPC rebuild is only required 1.6
just seen the xecuter3 install instructions for versions 1.0 to 1.5 is much easier - not so much soldering required! only has one difficult solder point (D0) the rest of the soldering is relatively easy. if you need a hand let me know.
just tested and sucessfully installed latest xecuter bios. also verified that can still boot in disabled mode and play fifa2005! everything looking good - now need to test with a backed up game
only downside is that not possible to play online
using "xbox live" service with modchipped machines -
believe that microsoft have way to detect modchipped
machines and will ban you from the service (even when modchip is not activated).
« Last Edit: November 20, 2004, 09:13:55 pm by rchadd »
wrxh8r
  • Last login:April 02, 2008, 11:30:49 pm
  • idiot extraudineer
Re:phew! successfully modchipped my xbox!
« Reply #1 on: November 21, 2004, 04:52:06 pm »
My cheapo aladdin with duel boot works online fine im sure an xecuter wont have a problem.
Your never alone with a rubber duck
