Author Topic: Having trouble with ini files, help please.  (Read 2789 times)
Apollo
    • Eight Bells
« on: November 10, 2004, 12:53:50 am »
Ok so I'm using windows command line 0.86b and Mamewah. I have Arcade VGA so I've used the Arcade VGA res tool to create seperate ini files for each rom. My problem is that there is no way I'm going in to each ini file to make changes so how do I make a "global" ini file that will take precedence where I can put things like mouse 1, skip disclaimer 1, skip game info 1 etc?
Step by step would be awesome for this computer idiot. Cheers.
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re:Having trouble with ini files, help please.
« Reply #1 on: November 10, 2004, 01:19:08 am »
read the windows.txt file  ;)
Apollo
    • Eight Bells
« Reply #2 on: November 10, 2004, 01:28:37 am »
"The settings in the later ini's override those in the earlier ini's." taken directly from windows.txt
Yeah thanks I have read the file. I'm not actually using DOS so as I said instructions for a computer illiterate would be really handy.
papaschtroumpf
  • Have a Cow!
« Reply #3 on: November 10, 2004, 01:45:09 am »
right at the top of windows.txt:
-createconfig / -cc
   Creates the default MAME.INI file. All the following configuration
   options can be permanently changed by editing this configuration file.
-showconfig / -sc
   Displays the current configuration settings. If you route this to a
   file, you can use it as an INI file. For example, the command:
      mame -showconfig >mame.ini
   is equivalent to -createconfig.
 ;D    ;D    ;D
« Last Edit: November 10, 2004, 01:45:56 am by papaschtroumpf »
Apollo
    • Eight Bells
« Reply #4 on: November 10, 2004, 02:46:26 am »
When I bring up the DOS prompt and type
-createconfig / cc nothing happens it says not recognised as a command or something like that.
cdbrown
  • Bowowow
« Reply #5 on: November 10, 2004, 03:44:12 am »
bring up the dos prompt and navigate your way to your mame folder
then type
mame -cc
if you want to create the ini file
createconfig / cc <- giving you the option to either type createconfig or the simpler cc
papaschtroumpf
  • Have a Cow!
« Reply #6 on: November 10, 2004, 10:55:07 am »
then type
mame -cc
yes =, the options listed in windows.txt are command line options to the MAME executable.
Apollo
    • Eight Bells
« Reply #7 on: November 10, 2004, 02:44:22 pm »
Thanks folks, how to I navigate to my mame folder in DOS?
Any chance someone can show me exactly what to do and type, sorry.
wj2k3
  • Last login:August 22, 2006, 12:23:48 am
  • Not!
« Reply #8 on: November 10, 2004, 03:06:03 pm »
click "Start"
click "RUN"
type "CMD" and then press Enter
type "C:" and then press Enter to switch to C: drive if not already there (assumes you installed Mame on your c: drive)
type "CD \MAME" and then press Enter to switch to your Mame Directory (assumes you installed Mame in the directory C:\Mame)
Apollo
    • Eight Bells
« Reply #9 on: November 10, 2004, 05:15:36 pm »
Cool, thanks for that. I'll give it a whirl tonight after work. Can't believe I've been doing this hobby for so long and I still feel rather dumb sometimes. Soooo much to know.
Bomber
  • Last login:July 20, 2006, 01:48:39 am
« Reply #10 on: November 10, 2004, 09:34:26 pm »
Give me a call or send me an email if you want some help. I need to see the beast in action anyway  ;D
Never get into fights with ugly people - they have nothing to lose.
Apollo
    • Eight Bells
« Reply #11 on: November 10, 2004, 10:26:15 pm »
Awesome David, thanks buddy. Mamewah 1.52 looks like a bit of a mission to install. I'll give you a bell.
Bomber
« Reply #12 on: November 10, 2004, 10:32:43 pm »
No sweat man. I'll be in Sydney Fri/Sat/Sun - back on Sunday evening. Maybe try to tee it up for one night next week. I'm sure you find find plenty of other things to do in the meantime. Maybe starting the cocktail  ;)
