Author Topic: what am i missing. arcadeOS shows no games  (Read 2555 times)
kcorcoran
  • Trade Count: (-1)
  • Last login:July 03, 2024, 12:42:02 pm
« on: November 09, 2004, 10:05:29 pm »
ok. i've read and re-read the documentation. searched google endlessly. but i must be missing something.
here's what i have....
arcadeOS unzipped to c:\aos
mame36 unzipped to c:\mame
i start up arcade os and get NOTHING in the games list.
i have cycled through the lists.. through the emus.. through the orientations.. nothing. not a game in sight. what am i doing wrong here?
SirPeale
  • Green Mountain Man
Re:what am i missing. arcadeOS shows no games
« Reply #1 on: November 09, 2004, 10:42:35 pm »
look in arcadeos.cfg
find the legacy support option.
Change whatever it is now to it's polar opposite.
Delete all .lst and .rm* files
run arcadeos
kcorcoran
  • Trade Count: (-1)
« Reply #2 on: November 10, 2004, 07:04:47 am »
ok. that didn't seem to work either.  ???
i turned on logging to see whats happeneing and it's finding the ROMs in the mame folder...
but i'm getting this error for each ROM.
name NOT found for 0 : ARKNID2U
name NOT found for 1 : ARTWORK
name NOT found for 2 : BERABOHO
name NOT found for 3 : CFG
name NOT found for 4 : COMBASCJ
and so on.
i guess i'm almost there. any other advice?
SirPeale
« Reply #3 on: November 10, 2004, 07:52:39 am »
Does it instantly stop when you type arcadeos and go to the blank menu, or does it show the command being used to generate your gamelist?
This is a very basic setup, I'm not sure what you're doing wrong.  Switching the legacy support and then rerunning AOS should have fixed that.
Failing that, you can reinstall AOS, maybe something got corrupted.
kcorcoran
  • Trade Count: (-1)
« Reply #4 on: November 10, 2004, 01:15:59 pm »
actually it shows me confirmation it's building lists.. then it goes back into command prompt.
when i try to run it again after the lst and rms files have been created it loads the frontend but again, there's no roms listed. i cycled through all the custom lists, emulators and orientations just to make sure nothing was disabled.
i'll try to download again later today.
would this have anything to do with runing this in XP?
SirPeale
« Reply #5 on: November 10, 2004, 01:46:09 pm »
You're running this under XP?  Jeeze, why?  It's a DOS program.  Use MameWAH or Kymera.  Better yet, switch it over to DOS.  Unless you don't have drivers for your audio.
kcorcoran
  • Trade Count: (-1)
« Reply #6 on: November 10, 2004, 10:45:16 pm »
sorry man. forgot to mention. this will eventually go on a dos box.. i was just trying to get it all set up to copy over to the machine.
k.
