Author Topic: Which arcade monitor?  (Read 2404 times)
blueoakleyz
  • Last login:November 01, 2004, 09:03:08 pm
  • PS2-Arcade
« on: November 01, 2004, 12:47:43 am »
We would like a 25" arcade monitor to hook up to a PC via an arcadeVGA video card (what kind of cable for that?), which monitor would be best?
is this one good?
http://www.happcontrols.com/monitors/496254vp3.htm
any other suggestions?
seibu
  • Last login:March 28, 2007, 12:55:34 pm
Re:Which arcade monitor?
« Reply #1 on: November 01, 2004, 06:12:08 am »
Yeah, that's a nice monitor. Bear in mind that if you're using the ArcadeVGA card in Windows, you wont be able to take advantage of the EGA (25khz) mode. You'll need to use AdvanceMAME in DOS or Linux to output 25Khz signals.
If you just want to use authentic Arcade resolutions using a simple ArcadeVGA / Windows setup, you'd be best getting a simple CGA-only (15Khz) monitor. If you're in the US then Happs is a good place to get one of those, unless you know somewhere locally. Wells gardner and Vision Pro both do perfectly decent and relatively cheap 15Khz monitors that you can buy through Happs. I think WG will also sell directly.
If you're in the UK, check out the Hantarex web site under "offers". I picked up a beautiful 15Khz monitor from there for
« Last Edit: November 01, 2004, 06:13:33 am by seibu »
