Author Topic: custom lists  (Read 3193 times)
spottydog
  • Last login:July 13, 2007, 07:58:40 am
custom lists
« on: October 24, 2004, 06:17:36 pm »
Hi, I'm using v0.97 of Mamewah with Mame v0.82.
I installed v0.82 of the catver file in both folders (Mamewah & Mame).
I select a custom list and press '1' on Generate Custom List using Filters. Unfortunately, the screen remains unchanged.
Can anybody help?
                 thanks
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
Re:custom lists
« Reply #1 on: October 24, 2004, 07:37:25 pm »
Refresh your main list, then generate a custom list.  the catver.ini file should be in the mame folder and pointed to in your config file.
spottydog
Re:custom lists
« Reply #2 on: October 25, 2004, 11:09:33 am »
Hi, I don't understand, how do you point to the catver.ini file? I followed your suggestion - still no change.
Re:custom lists
« Reply #3 on: October 26, 2004, 04:54:28 am »
In MW v0.97, you can't.  You must place catver.ini in your emulators root folder, and refresh the list.
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re:custom lists
« Reply #4 on: October 26, 2004, 03:38:43 pm »
I have a question regarding custom lists: I have done lists by category using catver.ini filters, but I'm thinking about removing some games from the list (don't play well, boring, ...). The easiest way to do this is to use the built in "remove game from list", but am I right to assume that if I ever upgrade my rom set, I will have to start over? or doess mamewah actually keep a list definition of "this list is card and majong games except for this one, this one, and this one" so that I could re-apply the filter to a new rom set?
It would be a pretty cool feature to have (either have an "update gamelist" option, or simply delete the filter if you want it rebuilt from scratch?) just an idea.
Re:custom lists
« Reply #5 on: October 27, 2004, 06:01:53 am »
Unfortunately you would have to do it all over again if you ever refresh the main list (unless you don't mind the other lists to be 'out of date').
I'd like to make some system eventually to do exactly as you describe - v2 will have this if all goes well...
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re:custom lists
« Reply #6 on: October 27, 2004, 06:50:16 am »
...and in the meantime, Dragon King does its filtering this way.
-Steve
spottydog
Re:custom lists
« Reply #7 on: October 27, 2004, 03:49:40 pm »
Hi, catver.ini is in the mame folder amongst the folders and executables. I have catver.ini v0.82 for use with mame v0.82. I downloaded the catver file from catlist. I refresh the games list but the screen remains unchanged when I try to generate a custom list.
catver.ini is in my mamewah folder and the mame\cfg folder too.
Re:custom lists
« Reply #8 on: October 28, 2004, 06:00:01 am »
spottydog
Re:custom lists
« Reply #9 on: October 28, 2004, 10:35:13 am »
I deleted the unneeded (?) files. I refreshed the main list and tried to generate a custom list again (without success).
papaschtroumpf
  • Have a Cow!
Re:custom lists
« Reply #10 on: October 28, 2004, 10:41:36 am »
did you put catver.ini in the MAME (not MAMEWAH) root folder? (just in case you didn't get MinWah's previous posts).
spottydog
Re:custom lists
« Reply #11 on: October 30, 2004, 12:26:39 pm »
Yes I did but still no change.....
