Author Topic: I NEED HELP!! CONNECTING EYGO MONITOR TO ARCADE!! WHAT WIRES MEAN WHAT???  (Read 7337 times)
yamaha147
  • Last login:September 11, 2002, 11:24:38 am
Hi,
I just bought the Mortal Kombat arcade and got a Eygo 19 in monitor
to try to connect together in the cabinet. I don't know what I'm
doing!!! There is a green, white, red, orange, yellow, blue, black,
gray, and purple wires coming from the monitor. From the game board
comes a red, green. brown, black and white wires. I
dont know what to connect to what..I dont have a manual either so I cannot find out what wire is what.. Can anyone please help me
at all???email me at yamaha147@copper.net
Thanks alot-Brian ??? ???
SNAAAKE
  • -Banned-
Re:I NEED HELP!! CONNECTING EYGO MONITOR TO ARCADE!! WHAT WIRES MEAN WHAT???
« Reply #1 on: September 11, 2002, 02:48:15 pm »
haha..very funny..
whats you eygo monitor?
if its vga only then no way to play your board...unless you get real cga/ega arcade monitor with r/g/b/sync/ground wires coming out of the monitor.vga wont display your jamma pcb.
thats all i know.
BobA
  • What Me Worry?
« Reply #2 on: September 11, 2002, 08:38:28 pm »
I can help with the Mortal Kombat cabinet wires for Mortal Kombat 1
White - Sync
Red - Video Red
Green - Video Green
Brown - Video Blue
Shield(Black) - Ground
Snaaake is right on.
These are standard arcade monitor signals so won't work with your Eygo if it is a vga monitor. Perhaps you could provide a model number or some other info on the Eygo.
If you Eygo is a vga monitor you could probably build a MAME machine by adding a PC and Jpac and emulate MK1.
BobA
yamaha147
« Reply #3 on: September 11, 2002, 10:03:47 pm »
The Model is AMN19V-RB
Hope this helps!!! Let me know if you need more info...Thanks-Brian
BobA
  • What Me Worry?
« Reply #4 on: September 12, 2002, 12:19:40 am »
Did a google search and got these specs for that monitor.  It is vga and will not display the output of your MK card.
These are Eygo 19" arcade monitors being sold on
eBay recently.
Specs:
Power Supply
Switch mode power supply
Dual AC input range
Jumper selectable
No isolation transformer required
Input Signal
Video - RGB analog, positive, 0.7 Vp-p.
Impedance - 75 ohms, terminated.
Rise Time - less than 25 nanoseconds.
Bandwidth - DC to 25 MHz (at - 3dB), mode 3.
Resolution - Model
1. 640 x 350 (70Hz refresh)
2. 640 x 400 (70Hz refresh)
3. 640 x 480 (60Hz refresh)
Sync. - TTL, positive or negative. Monitor circuitry will
automatically determine and adjust for VGA Horizontal Scan - Frequency 31.5KHz nominal
Capture range-30.5~32.5KHz
Active video - full width display of video
signals with active video from 25 to 28usec.
Linearity - plus or minus 5%
Vertical Scan - Frequency 60/70Hz
Capture range 47~85Hz
Picture Size Regulation
2%
Geometric Distortion
plus or minus 1.5% (max)
Environmental Conditions
Temperature 100 ~ 550C
Humidity 10~90%, no condensation
High Voltage
13"=23KV, 20"=25KV, with integral X-radiation
Shut-down protection
Degaussing
Automatic, operating at beginning of each power-up
cycle, provided the monitor has been turned off for
at least 20 minutes.
BobA
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #5 on: September 12, 2002, 12:54:09 am »
I don't know what it is called, I just know it is expensive, but there is a video converter where you can hook up RGB and output VGA.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #6 on: September 12, 2002, 01:20:52 am »
Any upscanner that takes in purge RGB is going to be professional quality (and usually around $500).  But most gamers import the X-RGB2 (or new X-RGB2 Plus) from Japan.  These are professional quality up scanners that use a 21 pin japanese scart input (RGB) and can output from 640x480 to 1024x768...all at a consumer price of $250 (at http://www.dcslinks.com/pc/mc_xrgb2plus.htm).  The older X-RGB2 comes on ebay every now and then from $100 to $200.
-Dave
« Last Edit: September 12, 2002, 02:15:02 am by Dave_K. »
Dave_K.
    • Arcade Fever
« Reply #7 on: September 12, 2002, 01:25:59 am »
-Dave
SNAAAKE
  • -Banned-
« Reply #8 on: September 12, 2002, 01:41:36 am »
http://www.weiya.com.tw/converter/converter.htm
this should work.
but the question is why would not play mk1 on mame..
that will save you all the hassle..
SirPoonga
  • Puck'em Up
« Reply #9 on: September 12, 2002, 02:45:50 am »
this should work.
Nice link, NOW, realistically, where can you find something like that?  Not calling taiwan!!
I am curious as I might try hooking up my ddragon and ddragon2 pcbs in my cab.
SNAAAKE
  • -Banned-
« Reply #10 on: September 12, 2002, 02:10:12 pm »
i was expecting crap from people for this one anyways...lol...
here in US...
i know a guy locally that sells for $89.the arcade warehouse.he wont ship or anything...thats the problem..
SirPoonga
  • Puck'em Up
« Reply #11 on: September 12, 2002, 03:42:13 pm »
here in US...
That still doesn't help....
SNAAAKE
  • -Banned-
« Reply #12 on: September 12, 2002, 05:38:10 pm »
i saw a site long time ago..
i did look and found nothin today..if i find..i will post..
hang in there  :)
« Last Edit: September 12, 2002, 05:39:32 pm by SNAAAKE »
Rod1968
  • Last login:February 03, 2007, 10:19:45 pm
« Reply #13 on: September 16, 2002, 07:38:43 am »
this should work.
I contacted
via email and it looks like there more than willing to deal
direct. $60 dollars for the converter, I just wonder how
much the shipping will cost. I would like to use this with
a 19" eygo I have and my track and field that has a broken
monitor in it.
This is the reply they sent me
Dear Rodney,
Good day! We are in receipt of your inquiry with thanks.
As per your requested, we are pleased to quote the price for your reference as below.
ACV-01 CGA to VGA converter   @USD60/pc
              -CGA gaming signal can display on PC Monitor or TFT Monitor
              -Normal resolution enhance to HI-resolution
              -Display frame sharpness and tiny pixel for user
              -Support either combine sync. H/V and separate sync. H, V frequency and
               negative/positive sync type.
              -VGA bypass control by switch
              -Contrast adjust by a VR.
Also please let us know which of IC Board will you meet.
If you have any further information/comments with our offers, please
do not hesitate to contact with us immediately.
Looking forward to hearing from you soon and thanks in advance.
Best regards,
Miss Angel Hou
Overseas Dept.
Huai I Electronic Co., Ltd.
No. 18, Alley 38, Lane 129,
Cheng S. 1 ST., Yung Kang City,
Tainan Hsien, Taiwan, R.O.C.
Tel: 886-6-253-2771
Fax: 886-6-253-2827
E-mail: weiya666@ms77.hinet.net
Web Site: www.weiya.com.tw
Rodney
